I try to access my audio driver via the below command:
test_audio.py
import pygame
file = '1.wav'
pygame.init()
pygame.mixer.init()
pygame.mixer.music.load(file)
pygame.mixer.music.play()
I could use the above code in the terminal when I am not access the container, but after accessing the container, I could not play it.
The error that I received was:
pygame.error(): no audio driver
Solution which I tested:
import os
os.environ['SDL_AUDIODRIVER'] = 'dsp'
cat /proc/asound/cards
The above code could not work too but it work when I try it on the terminal without accessing the container
You will need to mount the nodes to get access within the container.
Could you check the below topic for information first?
Hi All!
I am working on an Audio Recording container for a use case I am working on. For this I use PulseAudio and Python to open a USB Microphone and start creating a recording.
All of this works fine while running python main.py on my Nvidia Jetson device. However, when I run this in Docker I always get the following error with the kernel crashing and rebooting the device.
tegra-xusb 3610000.xhci: WARN: buffer overrun event on endpoint
Would anyone know where to look at or how to resolve t…
Thank you and yes, I refered to it and trried the below code but still failed’;
sudo docker run -it -v /home/jetson/work:/work -d --name test_audio --gpus all -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix --runtime nvidia -v /usr/lib/aarch64-linux-gnu:/usr/lib/aarch64-linux-gnu -v /lib/aarch64-linux-gnu:/lib/aarch64-linux-gnu --device=/dev/snd -v /dev/snd:/dev/snd:ro --device=/dev/bus/usb -v /dev/bus/usb:/dev/bus/usb:ro --device /dev/video0:/dev/video0:mwr --network host nvcr.io/nvidia/l4t-pytorch:r32.5.0-pth1.7-py3 /bin/bash
Also, i try to check:
arecord -l
and below is my output:
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 0: ADMAIF1 CIF ADMAIF1-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 1: ADMAIF2 CIF ADMAIF2-1 []
Subdevices: 1/1
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 2: ADMAIF3 CIF ADMAIF3-2 []
Subdevices: 1/1
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 3: ADMAIF4 CIF ADMAIF4-3 []
Subdevices: 1/1
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 4: ADMAIF5 CIF ADMAIF5-4 []
Subdevices: 1/1
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 5: ADMAIF6 CIF ADMAIF6-5 []
Subdevices: 1/1
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 6: ADMAIF7 CIF ADMAIF7-6 []
Subdevices: 1/1
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 7: ADMAIF8 CIF ADMAIF8-7 []
Subdevices: 1/1
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 8: ADMAIF9 CIF ADMAIF9-8 []
Subdevices: 1/1
card 1: tegrasndt210ref [tegra-snd-t210ref-mobile-rt565x], device 9: ADMAIF10 CIF ADMAIF10-9 []
Subdevices: 1/1
it did not show my usb speaker.
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Could you play the wav file inside the container with aplay ?
