I am trying to play a sound within my docker container (using nvidia container runtime) on TX2 through USB headphones.
I have tried using ALSA within my container and sharing my sound cards using --device /dev/snd
. I am also running as root
within my container so the problem is not with my group permissions.
If I run aplay -l
on my host TX2, my USB headphones show up as an audio device and if I run aplay -l
inside my container they no longer do.
Any advice would be appreciated. If I have to use pulseaudio I can as well.
Hello!
I tried the following and this worked …
$ docker pull ailispaw/alsa-utils
$ sudo usermod -aG docker $USER
$ sudo reboot
Then with aplay I can see my USB headset …
$ docker run --device /dev/snd ailispaw/alsa-utils aplay -l
card 2: Headset [Logitech USB Headset], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
And I can run speaker-test to verify audio playback …
$ docker run --device /dev/snd ailispaw/alsa-utils speaker-test -D hw:Headset,0 -c 2 -r 48000 -F S16_LE -t sine -f 500
You could try the same docker image to see if this works for you.
Regards,
Jon
