Can not make the USB Speaker/Mic. working on Jetson TX2
Dear Support,
I have been struggling to get the USB speaker and microphone (plug-in) working on the TX2.
Could you please let me know how to make them working and how to set up in a easy way?
If you knew a working device, please let me know as well.
Thanks so much
Jimmy
Followings are the devices I have used:
USB sound card for speaker and mic.
HDMI converter with 3.5 mm Audio output pole - can not get the audio output as well
For USB microphone, please check
https://devtalk.nvidia.com/default/topic/1069714/jetson-nano/usb-microphone-on-jetson-nano/post/5418893/#5418893
For speaker, please run ‘aplay -l’ and check if USB audio is listed.
Yes after I have run the “aplay -l” and found that my USB speaker is Card 2 and Device 0.
But how I can make that work since after I have plugged in the 3.5 mm audio jack in and find no sound?
Jimmy
Finally I have figured out how to make the external USB speaker working:
  1. In ubuntu desktop, go Settings
  2. in Sound menu, pick up the Seakers (USB PnP Audio Device)
That is it.
