Hi All,
I need information on Thermal management for Industrial and commercial version of TK1. I read from the TRM, Under Thermal sensor (sec37.3.1)
“Program thermal thresholds. Thresholds for heavy hardware throttling and THERMTRIP should be in fuses.”
- Do we have option to program the fuses
- Does this fuse settings varies for Industrial and commercial version of Tegra K1
- I have both Industrial and commercial version of Tegra K1, DVFS table and Thermal trip point for CPU, GPU and MEM varies between Industrial and commercial version of Tegra K1. I have programmed both the Tegra K1 with same binary. Is this expected behavior.
- Industrial Version of board start reducing the frequency and voltage in lower temperature than commercial version of board. Is this expected behavior.
Can somebody explain more about the difference between Industrial and comercial Versions?
Thanks and Regards,
Jeslin Paul
