DP0&DP1&DP2是否也有同样的问题?
870251475
14
Related topics
| Thor DP 2/3 , cannot display,load driver error | 3 | 350 | July 7, 2026 | |
| Thor uses DP1 for display cannot work | 54 | 336 | November 11, 2026 | |
| AGX Thor / JetPack 7.2 (R39.2.0): DisplayPort outputs dead - framebuffer@0,0 carveout is empty, reproduces on a clean official install | 23 | 608 | October 14, 2026 | |
| Jetpack7.1 Jetson thor DP3 exception when cable plugin | 1 | 131 | May 4, 2026 | |
| A DCE error on Jetson Thor caused the system to freeze abnormally | 12 | 401 | September 11, 2026 | |
| [jetson thor][display port]How to Modify the DP Port to DP1 | 71 | 1301 | March 25, 2026 | |
| Nvidia-modeset: ERROR: GPU:0: The requested configuration of display devices(FDR iFOUND (DP-0), FDR iFOUND (HDMI-0)) is not supported on this GPU | 40 | 1159 | March 19, 2026 | |
| R3840 上电开机显示器不显示 | 5 | 88 | November 23, 2026 | |
| AGX Thor shows abnormal display when using the DP interface to connect the monitor | 2 | 226 | November 5, 2025 | |
| Configure display on AGX THOR | 34 | 806 | August 17, 2026 |
