Hello to everyone browsing this post,
Regarding the use of the AGX Thor device, I have encountered an abnormal phenomenon.
After powering on the AGX Thor device and connecting a 4K monitor via the DP interface with a cable, the display shows abnormalities, with pixel dynamic disorder. Only rebooting the device, restarting the device, or performing a system soft reboot (Ctrl+Alt+Print Screen+r+e) can restore normal display.
The Jetpack version installed on the Thor device is as follows:
root@zzy:/home/zzy# cat /etc/nv_tegra_release
R38 (release), REVISION: 2.2, GCID: 42205042, BOARD: generic, EABI: aarch64, DATE: Thu Sep 25 22:47:11 UTC 2025# KERNEL_VARIANT:
ootTARGET_USERSPACE_LIB_DIR=nvidiaTARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidiaINSTALL_TYPE=
How should this issue be resolved?
