Thrust prefix sum slower than CPU?
I am using Thrust to calculate prefix sum on the GPU.
The function prefix_sum calculates the prefix sum on GPU and the function foo calculates the prefix sum on CPU.
This is my code - (Note I am also performing some additional pre-processing before performing the exclusive scan)
#include <iostream>
#include <thrust/device_vector.h>
#include <thrust/scan.h>
#include <cuda_runtime.h>
#include "device_launch_parameters.h"
#include <assert.h>
#include <chrono>
template <typename T, typename C>
__global__
void sub(T* output, const C* starter, const C* stopper, int64_t startsoffset, int64_t stopsoffset, int64_t n) {
  int thid = threadIdx.x + blockIdx.x * blockDim.x;
  if (thid < n) {
    C start = starter[thid + startsoffset];
    C stop = stopper[thid + stopsoffset];
    assert(start =< stop);
    output[thid] = stop - start;
void prefix_sum(T* output, const C* arr, const C* arr2, int64_t startsoffset, int64_t stopsoffset, int64_t length) {
  int block, thread;
  if (length > 1024) {
    block = (length / 1024) + 1;
    thread = 1024;
  else {
    thread = length;
    block = 1;
  T* d_output;
  C* d_arr, * d_arr2;
  cudaMalloc((void**)&d_output, length * sizeof(T));
  cudaMalloc((void**)&d_arr, length * sizeof(C));
  cudaMemcpy(d_arr, arr, length * sizeof(C), cudaMemcpyHostToDevice);
  cudaMalloc((void**)&d_arr2, length * sizeof(C));
  cudaMemcpy(d_arr2, arr2, length * sizeof(C), cudaMemcpyHostToDevice);
  sub<T, C> << <block, thread >> > (d_output, d_arr, d_arr2, startsoffset, stopsoffset, length);
  cudaDeviceSynchronize();
  thrust::device_vector<T> data(d_output, d_output + length);
  thrust::device_vector<T> temp(data.size() + 1);
  thrust::exclusive_scan(data.begin(), data.end(), temp.begin());
  temp[data.size()] = data.back() + temp[data.size() - 1];
  thrust::copy(temp.begin(), temp.end(), output);
  cudaFree(d_output);
  cudaFree(d_arr);
  cudaFree(d_arr2);
template <typename C, typename T>
void foo(T* tooffsets, const C* fromstarts, const C* fromstops, int64_t startsoffset, int64_t stopsoffset, int64_t length) {
  tooffsets[0] = 0;
  for (int64_t i = 0; i < length; i++) {
    C start = fromstarts[startsoffset + i];
    C stop = fromstops[stopsoffset + i];
    tooffsets[i + 1] = tooffsets[i] + (stop - start);
int main() {
  int const size = 70000;
  int starter, stopper, output;
  for (int i = 0; i < size; i++) {
    starter[i] = i;
    stopper[i] = i + 1;
  prefix_sum<int, int>(output, starter, stopper, 0, 0, size); // GPU Warm up
  auto start2 = std::chrono::high_resolution_clock::now();
  foo<int, int>(output, starter, stopper, 0, 0, size);
  auto stop2 = std::chrono::high_resolution_clock::now();
  auto time2 = std::chrono::duration_cast<std::chrono::microseconds>(stop2 - start2);
  std::cout << "Time taken for CPU = " << time2.count() << "\n";
  auto start1 = std::chrono::high_resolution_clock::now();
  auto stop1 = std::chrono::high_resolution_clock::now();
  auto time1 = std::chrono::duration_cast<std::chrono::microseconds>(stop1 - start1);
  std::cout << "Time taken for GPU = " << time1.count() << "\n";
My results are -
  • Time taken for CPU = 69
  • Time taken for GPU = 2140
also I am timing using the CPU timer chrono instead of the GPU timer cudaEvents() because I feel the additional non-cuda operations should also be timed considering that I am comparing the speed of two different approaches.
I am notably not calculating the average of several tests because I noticed that the difference was usually
similar.
I am not compiling in Debug mode.
cuda-memcheck does not yield any errors.
What could be happening? Especially since the GPU time is so much slower than the CPU time…
If you want to use chrono timers, that is fine, but make sure you use cudaDeviceSynchronize() before you start your GPU timing, and right before you end the timing.
With the current setup, you are considering the time to establish the CUDA context on the device and etc, which can be significant
Did not make a difference in times.
Increased the GPU time a little.
(Yes I did both at the same time)
In the future, providing your software and hardware stack allows for more insight into your issue.
  1. Your data set is too small to utilize a modern GPU. Depending on the resources of your GPU and CPU, it’s easily the case that your CPU (especially with -O3) finished first.
  2. It makes sense that added cudaDeviceSynchronize after your kernel. That stops the host code from proceeding until all GPU tasks have finished. Otherwise the code is return immediately after the kernel is launched.
  3. While I understand that you want to compare apples-to-apples by adding all memory management into your timing report, that is not the suggested why to utilize a GPU. For best performance, it is advised to perform memory allocation and transfers once at the initialization of your program, if possible perform all compute on the GPU, and then transfer any results. This may not be ideal for large, complex applications but it should be the model to go by.
  4. On my laptop, with an i7-8750H and a RTX2080 w/Max-Q, I get the following results.
size = 70000
Time taken for CPU = 308
Time taken for GPU = 363
size = 1000000
Time taken for CPU = 4377
Time taken for GPU = 2685
  1. Now if I look at the compute independently. You can see that it is a fraction of the GPU workload and nearly 40x faster than the CPU.
size = 1000000
Time taken for CPU = 4344
Time taken for Thrust = 113
Time taken for GPU = 2721
  1. Even if we turn on optimization on the CPU with -03, the GPU is still 12x faster.
size = 1000000
Time taken for CPU = 1367
Time taken for GPU = 2682
#include <iostream>
#include <cassert>
#include <chrono>
#include <vector>
__global__
  if (thid < n) {
    assert(start <= stop);
  int block, thread;
    thread = 1024;
  else {
    thread = length;
    block = 1;
  T* d_output;
  C* d_arr, * d_arr2;
  std::cout << "Time taken for Thrust = " << time1.count() << "\n";
  cudaFree(d_output);
  cudaFree(d_arr);
  cudaFree(d_arr2);
  tooffsets[0] = 0;
int main() {
  int const size = 1000000;
//   int starter, stopper, output;
  std::vector<int> starter (size);
  std::vector<int> stopper (size);
  std::vector<int> output (size + 1);
    starter[i] = i;
    stopper[i] = i + 1;
  prefix_sum<int>(output.data(), starter.data(), stopper.data(), 0, 0, size); // GPU Warm up
  foo<int, int>(output.data(), starter.data(), stopper.data(), 0, 0, size);
I would highly suggest you look at our Fundamentals of Accelerated Computing with CUDA C/C++ https://courses.nvidia.com/courses/course-v1:DLI+C-AC-01+V1/about. It covers a lot of the basics and gives you an understanding of how the GPU works.
