I have a customized double2_ class defined as follows
class double2_ {
public:
double2 c;
__host__ __device__ __forceinline __forceinline__ double2_(const double x_,const double y_) { c.x=x_; c.y=y_; };
// operator overloads...
Also, I have the Dmatrix GPU class defined as follows
template <typename OutType=DefaultType>
class Dmatrix
private :
int Rows_; // Number of rows
int Columns_; // Number of columns
OutType *data_; // Row-major order allocation
public:
// Constructor
Dmatrix(const int Rows,const int Columns) {
Rows_ = Rows;
Columns_ = Columns;
CudaSafeCall(cudaMalloc((void **)&data_, Rows_*Columns_*sizeof(OutType)));
I want to use thrust to perform a reduction of a Dmatrix<double2_> object. So, I have set up the following code
struct SumOperator
SumOperator() {};
__host__ __device__ double2 operator()(const double2& a,const double2& b) const {
double2 r; r.x = a.x+b.x; r.y = a.y+b.y;
return r; }
double2_ SumAll(const Dmatrix<double2_> &v)
double2 Zero = {0.0,0.0};
thrust::device_ptr<double2> dev_ptr_1((double2*)v.GetDataPointer());
thrust::device_ptr<double2> dev_ptr_2((double2*)(v.GetDataPointer()+v.GetNumElements()-1));
double2 out = thrust::reduce(dev_ptr_1,dev_ptr_2,Zero,SumOperator());
double2_ outcast; outcast.c.x = out.x; outcast.c.y = out.y;
return outcast;
I receive a large number of compilation errors, like
no suitable conversion function from "thrust::device_ptr<double2>" to "size_t" exists
no suitable constructor exists to convert from "unsigned int" to "thrust::device_ptr<double2>"
no operator "==" matches these operands
no instance of overloaded function "thrust::min" matches the argument list
"thrust::detail::backend::cuda::unordered_reduce_closure<InputIterator, Size, T, OutputIterator, BinaryFunction>::unordered_reduce_closure [with InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<double2>>, Size=thrust::device_ptr<double2>, T=double2, OutputIterator=thrust::detail::normal_iterator<thrust::device_ptr<double2>>, BinaryFunction=BB::SumOperator]" matches the argument list
which apparently do not have much to do directly with the code snippet above. All the errors are related, the compiler says, to the file reduce.inl.
What I’m doing wrong?
Thank you very much in advance.
