TierIV perception build error tensorrt
er.log (5.3 KB)
can you support building on agx orin / agx devkit this deployment? seems the problem is tensorrt versions discrepancies
any solutions for that?
Have you checked this with the repository owner?
It looks like the sample is tested with JetPack 4.6 on the Xavier board.
Prerequisites
  • ECU: Jetson AGX Xavier based ECU, …
  • Board support packages: NVIDIA L4T R32.6.1 (including Ubuntu 18.04) or higher
the issue at their github repository remains unanswered
Based on the log, the error is caused by some TensorRT API changes.
It’s recommended to check with the author to see if they can modify the source to be compatible with JetPack 5.
