Hi all,
i have a problem with my gstreamer pipeline.
When i try to read a RGBA tiff image with multifilesrc, gst goes to Internal data flow error.
But if i use a RGB tiff (without alpha channel) all works well.
This is my pipeline:
gst-launch-1.0 -e \
v4l2src device=/dev/video1 name=cam1 ! \
video/x-raw,width=1920,height=1080,framerate=30/1 ! \
videoflip method=rotate-180 ! \
videobox autocrop=true ! \
video/x-raw,width=1920,height=720,framerate=30/1 ! \
compositor name=mix sink_1::ypos=720 sink_1::xpos=1440 sink_2::ypos=720 ! \
gdkpixbufoverlay location=$OVERLAY offset-x=1749 offset-y=10 ! \
omxh265enc control-rate=3 iframeinterval=30 ! \
matroskamux name=mux ! \
multifilesink location=$OUTPUT next-file=5 max-file-duration=10000000000 \
v4l2src device=/dev/video2 name=cam2 ! \
video/x-raw,width=640,height=480,framerate=30/1 ! \
videoscale ! \
video/x-raw,width=480,height=360,framerate=30/1 ! \
mix. \
multifilesrc location=$DASHBOARD caps="image/tiff,framerate=30/1" ! \
avdec_tiff ! \
videorate ! \
mix. \
alsasrc device=hw:2,0 ! \
queue ! audioresample ! \
'audio/x-raw, format=(string)S16LE,layout=(string)interleaved, rate=(int)44100, channels=(int)1' ! \
voaacenc ! \
mux.
Making some research i found some people saying to use videomixer instead of compositor.
I tried it but output was very laggy and audio often skip.
