I have a program that uses the CQE to record tx/rx hardware timestamps on Connect X-7s and Bluefield-3 NICs. I am using PTP to sync my clocks.
Occasionally, I see timestamps that make no sense (they are extremely far in the past or future). I know this bug existed in the Connect X-7 and Bluefield-3 NICs, and that this bug was fixed, as I see the bug fix recorded in the firmware history for both the Connect X-7 and Bluefield-3 firmware that says: fixed the cr_space (Configuration Registers Space) in port configuration to prevent wrong timestamp of cqes
Updating the firmware for the Connect X-7s to the latest version allows my code to run as expected on the Connect X-7s. However, even though the bug fix for the Bluefield-3s was pushed in version 32.39.2048, and I am using a firmware version that was released much later (32.42.1000), I still have this timestamping issue when running the same code (that works on the Connect X-7s) on the Bluefield-3s.
Is there an issue with timestamping the cqes that I am unaware of, such as yet another bug in the Bluefield-3 firmware?
