Hi
I use the BlueField-3 card as the NVMe-oF Target, and the networking is as follows:
[X86/Initiator]----- NVMe-oF(RDMA)-------[BlueField/Target] — NVME-SSD
When I turn off the attr_offload(attr_offload=0), The test result is OK,
When I turn on the attr_offload(attr_offload=1), I get the following “XRQ NVMF backend ctrl timeout error” error in the logs, and the ctx of the offload is removing,
Every time 20 seconds after executing the connect command on the Initiator side, the “XRQ NVMF backend ctrl timeout error(22)” error will inevitably appear, 22 means IB_EVENT_XRQ_NVMF_BACKEND_CTRL_TO_ERR,
Can anyone explain why the XRQ NVMF backend ctrl has a timeout error and what could go wrong?
Thanks in advance for any assistance or suggestions.
I followed this doc:
https://enterprise-support.nvidia.com/s/article/howto-configure-nvme-over-fabrics--nvme-of--target-offload
07:15:15 kernel: [ 919.654806] nvmet: creating nvm controller 1 for subsystem testsubsystem for NQN nqn.2014-08.org.nvmexpress:uuid:ef0cec00-a846-11ea-8000-ac1f6b3ea450.
07:15:15 kernel: [ 919.692117] nvmet_rdma: connect request (4): status 0 id 0000000020477746
07:15:15 kernel: [ 919.705730] nvmet_rdma: added mlx5_0.
07:15:15 kernel: [ 919.717137] nvmet_rdma: nvmet_rdma_create_queue_ib: max_cqe= 8191 max_sge= 30 sq_size = 102 cm_id= 0000000020477746
07:15:15 kernel: [ 919.738992] nvmet_rdma: established (9): status 0 id 0000000020477746
07:15:18 kernel: [ 922.503156] nvmet_rdma: connect request (4): status 0 id 00000000675c1077
07:15:18 kernel: [ 922.516756] nvmet_rdma: added mlx5_0.
07:15:18 kernel: [ 922.528174] nvmet_rdma: nvmet_rdma_create_queue_ib: max_cqe= 8191 max_sge= 30 sq_size = 102 cm_id= 00000000675c1077
07:15:18 kernel: [ 922.550005] nvmet_rdma: established (9): status 0 id 00000000675c1077
07:15:18 kernel: [ 922.562943] nvmet_rdma: using dynamic staging buffer 0000000053e1f05e
07:15:18 kernel: [ 922.622009] nvmet: Adding offload ctx 0 to configfs
07:15:18 kernel: [ 922.634362] nvmet: adding queue 1 to ctrl 1.
07:15:18 kernel: [ 922.674259] nvmet: adding queue 2 to ctrl 1.
07:15:20 kernel: [ 924.922805] nvmet: adding queue 47 to ctrl 1.
07:15:20 kernel: [ 924.972539] nvmet: adding queue 48 to ctrl 1.
07:15:23 kernel: [ 927.351996] nvmet: ctrl 1 update keep-alive timer for 5 secs
07:15:25 kernel: [ 929.909981] nvmet: ctrl 1 update keep-alive timer for 5 secs
07:15:28 kernel: [ 932.467996] nvmet: ctrl 1 update keep-alive timer for 5 secs
07:15:30 kernel: [ 935.026018] nvmet: ctrl 1 update keep-alive timer for 5 secs
07:15:33 kernel: [ 937.584047] nvmet: ctrl 1 update keep-alive timer for 5 secs
07:15:35 kernel: [ 940.142050] nvmet: ctrl 1 update keep-alive timer for 5 secs
07:15:37 kernel: [ 941.661828] nvme 0000:11:00.0: received IB Backend ctrl event: XRQ NVMF backend ctrl timeout error (22) be_ctrl 00000000f9eb18d8 id 0
07:15:37 kernel: [ 941.685916] nvmet: Removing offload ctx 0 from configfs
Version:
BlueField-3 SmartNIC Main Card (900-9D3C6-00SV-DA0)
Linux 5.15.0-1032-bluefield
MLNX_OFED_LINUX-23.10-1.2.0
The function call stack for the IB_EVENT_XRQ_NVMF_BACKEND_CTRL_TO_ERR :
mlx5_srq_table->nb.notifier_call
srq_event_notifier
mlx5_ib_nvmf_backend_ctrl_event
nvmet_rdma_backend_ctrl_event
event(22) : IB_EVENT_XRQ_NVMF_BACKEND_CTRL_TO_ERR
cat /sys/module/nvme/parameters/num_p2p_queues
modprobe nvmet
modprobe nvmet-rdma
mkdir /sys/kernel/config/nvmet/subsystems/testsubsystem
echo 1 > /sys/kernel/config/nvmet/subsystems/testsubsystem/attr_allow_any_host
echo 1 > /sys/kernel/config/nvmet/subsystems/testsubsystem/attr_offload
mkdir /sys/kernel/config/nvmet/subsystems/testsubsystem/namespaces/1
echo -n /dev/nvme1n1 > /sys/kernel/config/nvmet/subsystems/testsubsystem/namespaces/1/device_path
echo 1 > /sys/kernel/config/nvmet/subsystems/testsubsystem/namespaces/1/enable
mkdir /sys/kernel/config/nvmet/ports/1
ls /sys/kernel/config/nvmet/ports/1
echo 4420 > /sys/kernel/config/nvmet/ports/1/addr_trsvcid
echo 10.192.2.20 > /sys/kernel/config/nvmet/ports/1/addr_traddr
echo “rdma” > /sys/kernel/config/nvmet/ports/1/addr_trtype
echo “ipv4” > /sys/kernel/config/nvmet/ports/1/addr_adrfam
ln -s /sys/kernel/config/nvmet/subsystems/testsubsystem/ /sys/kernel/config/nvmet/ports/1/subsystems/testsubsystem
mlx5_fw: 0000:03:00.0 [0x2d20d6e56ec4] 0 [0x5] handle_nvmf_respond_exception sending_uapp_sw_cqe: gvmi: 0x0,qpn: 0x129
mlx5_fw: 0000:03:00.0 [0x2d20d6e5898c] 0 [0x5] handle_ace_req_cqe_error release: gvmi 0x0, tgt_num 0x10, qpn 0x129, action: 0x80000004
Thanks for sharing details.
Please make sure the current DPU firmware is updated.
https://network.nvidia.com/support/firmware/bluefield3/
You can run the below command inside the DPU to upgrade the firmware (it will choose the correct version automatically):
/opt/mellanox/mlnx-fw-updater/mlnx_fw_updater.pl
If you upgrade the firmware, please perform the full power cycle of the server (cold boot) and re-try the test.
If the issue is still present with the recommended firmware, please open a support case in Nvidia portal, and it will be handled according to the support entitlement.
Best Regards,
Anatoly
Hello, I meet the same error: received IB Backend ctrl event: XRQ NVMF backend ctrl timeout error (22) when I used the nvmf Target offloading with Bluefield-2.
I also used the MLNX_OFED_LINUX-23.10-2.1.3.1-rhel7.9-x86_64.
Do you find the solution?
sr114
May 10, 2024, 9:45am
11
I have the same problem. NVMEoF with offload works for some short time, max about 2 hours at very small load.
[23642.359750] nvme 0000:07:00.0: received IB Backend ctrl event: XRQ NVMF backend ctrl timeout error (22) be_ctrl 00000000ffcff958 id 6
[23642.361142] nvmet: Removing offload ctx 6 from configfs
On the target side:
debian 12.1
kernel: 6.1.0-10-amd64
41:00.0 Infiniband controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex]
On the initiator side:
Oracle Linux Server release 8.9
kernel: 5.4.17-2136.330.7.1.el8uek.x86_64
01:00.0 Infiniband controller: Mellanox Technologies MT27700 Family [ConnectX-4]
So in your case, you have no Bluefield DPU at all?
Hi zhangqi.public,
I’m curious about how you obtained this function call stack. Did you use GDB? If so, could you explain the steps you followed?
