Hello!
I’ve been trying to get the VK_KHR_ray_tracing extension to work. I’ve create a minimal program that compiles that just outputs solid red colour in the raygen shader. I’m now trying to setup an acceleration structure to actually be able to use the extension properly.
The BLAS builds just fine, even if I don’t use it, I can run the program with Nsight and the BLAS is correctly visualized, the validation layers aren’t complaining, all is well.
However, if I try building the TLAS using the BLAS I created, it messes up the program. The command buffer that builds it returns VK_SUCCESS on submission, but as soon as I submit any other buffer to the GPU, I get a Device Lost error.
I get no complaints from the validation layers.
I can do all the work for setting up the TLAS, and as long as I don’t actually submit the buffer to the queue, everything works (but no TLAS is built). I can also build the TLAS without any problems if I set it to have 0 geometries.
I’ve ran a few sample programs for the extension, and they do work. The program I’m working on also has a simple, but functional raster pipeline, and it reuses most of the systems I’ve been using for this (wrappers for images, buffer, command buffers, a memory manager, etc). Everything works there with zero complaints from the validation layers.
Here’s the code that deals with the acceleration structures, you can find the rest on GitHub:
#include "AccelerationStructure.h"
#include "VulkanContext.h"
AccelerationStructure AccelerationStructures::createBottomAccelerationStructure(Mesh& mesh, vk::Buffer& vertices) {
vk::AccelerationStructureCreateGeometryTypeInfoKHR geometryTypeInfo;
geometryTypeInfo.geometryType = vk::GeometryTypeKHR::eTriangles;
geometryTypeInfo.maxPrimitiveCount = mesh.getIndexCount() / 3;
geometryTypeInfo.indexType = vk::IndexType::eUint32;
geometryTypeInfo.maxVertexCount = 33 * 33 * 33;
geometryTypeInfo.vertexFormat = vk::Format::eR32G32B32Sfloat;
geometryTypeInfo.allowsTransforms = VK_FALSE;
vk::AccelerationStructureCreateInfoKHR createInfo;
createInfo.type = vk::AccelerationStructureTypeKHR::eBottomLevel;
createInfo.flags = vk::BuildAccelerationStructureFlagBitsKHR::ePreferFastTrace;
createInfo.maxGeometryCount = 1;
createInfo.pGeometryInfos = &geometryTypeInfo;
AccelerationStructure as;
as.structure = VulkanContext::get()->m_logicalDevice->createAccelerationStructureKHRUnique(createInfo);
vk::AccelerationStructureMemoryRequirementsInfoKHR memoryInfo;
memoryInfo.type = vk::AccelerationStructureMemoryRequirementsTypeKHR::eObject;
memoryInfo.buildType = vk::AccelerationStructureBuildTypeKHR::eDevice;
memoryInfo.accelerationStructure = *as.structure;
vk::MemoryRequirements memoryRequirements =
VulkanContext::get()->m_logicalDevice->getAccelerationStructureMemoryRequirementsKHR(memoryInfo).memoryRequirements;
as.memory = MemoryAllocator::allocate(
memoryRequirements,
vk::MemoryPropertyFlagBits::eDeviceLocal,
vk::MemoryAllocateFlagBits::eDeviceAddress);
vk::BindAccelerationStructureMemoryInfoKHR bindInfo;
bindInfo.accelerationStructure = *as.structure;
bindInfo.memory = *as.memory->memory;
bindInfo.memoryOffset = as.memory->offset;
VulkanContext::get()->m_logicalDevice->bindAccelerationStructureMemoryKHR(bindInfo);
vk::AccelerationStructureGeometryKHR geometry;
geometry.flags = vk::GeometryFlagBitsKHR::eOpaque;
geometry.geometryType = vk::GeometryTypeKHR::eTriangles;
geometry.geometry.triangles.vertexFormat = vk::Format::eR32G32B32Sfloat;
geometry.geometry.triangles.vertexData =
getBufferDeviceAddress<vk::DeviceOrHostAddressConstKHR>(vertices).deviceAddress;
geometry.geometry.triangles.vertexStride = vk::DeviceSize(sizeof(Vertex));
geometry.geometry.triangles.indexType = vk::IndexType::eUint32;
geometry.geometry.triangles.indexData.deviceAddress =
getBufferDeviceAddress<vk::DeviceOrHostAddressConstKHR>(mesh.getIndexBuffer()).deviceAddress;
const vk::AccelerationStructureGeometryKHR* const pGeometry = &geometry;
Buffer scratchBuffer = createScratchBuffer(
*as.structure,
vk::AccelerationStructureMemoryRequirementsTypeKHR::eBuildScratch,
"Bottom AS scratch buffer");
vk::AccelerationStructureBuildGeometryInfoKHR buildGeometryInfo;
buildGeometryInfo.type = vk::AccelerationStructureTypeKHR::eBottomLevel;
buildGeometryInfo.flags = vk::BuildAccelerationStructureFlagBitsKHR::ePreferFastTrace;
buildGeometryInfo.update = VK_FALSE;
buildGeometryInfo.srcAccelerationStructure = nullptr;
buildGeometryInfo.dstAccelerationStructure = *as.structure;
buildGeometryInfo.geometryArrayOfPointers = VK_FALSE;
buildGeometryInfo.geometryCount = 1;
buildGeometryInfo.ppGeometries = &pGeometry;
buildGeometryInfo.scratchData.deviceAddress =
getBufferDeviceAddress<vk::DeviceOrHostAddressKHR>(scratchBuffer.get()).deviceAddress;
vk::AccelerationStructureBuildOffsetInfoKHR offsetInfo;
offsetInfo.primitiveCount = mesh.getIndexCount() / 3;
offsetInfo.primitiveOffset = 0;
offsetInfo.firstVertex = 0;
offsetInfo.transformOffset = 0;
vk::AccelerationStructureBuildOffsetInfoKHR* pOffsetInfo = &offsetInfo;
std::unique_ptr<CommandBuffer> computeCmdBuffer = std::make_unique<CommandBuffer>(PoolType::eCompute);
computeCmdBuffer->get().buildAccelerationStructureKHR(1, &buildGeometryInfo, &pOffsetInfo);
computeCmdBuffer->submit(true);
vk::AccelerationStructureDeviceAddressInfoKHR addressInfo;
addressInfo.accelerationStructure = *as.structure;
as.address.deviceAddress =
VulkanContext::get()->m_logicalDevice->getAccelerationStructureAddressKHR(addressInfo);
return as;
AccelerationStructure AccelerationStructures::createTopAccelerationStructure(
AccelerationStructure& blas) {
geometryTypeInfo.geometryType = vk::GeometryTypeKHR::eInstances;
geometryTypeInfo.maxPrimitiveCount = 1;
createInfo.type = vk::AccelerationStructureTypeKHR::eTopLevel;
memoryRequirements,
vk::TransformMatrixKHR transformation = std::array<std::array<float, 4>, 3> {
1.0f, 0.0f, 0.0f, 0.0f,
0.0f, 1.0f, 0.0f, 0.0f,
0.0f, 0.0f, 1.0f, 0.0f
vk::AccelerationStructureInstanceKHR instance;
instance.transform = transformation;
instance.instanceCustomIndex = 0;
instance.mask = 0xFF;
instance.instanceShaderBindingTableRecordOffset = 0;
instance.flags = VkGeometryInstanceFlagBitsKHR(vk::GeometryInstanceFlagBitsKHR::eTriangleCullDisable);
instance.accelerationStructureReference = blas.address.deviceAddress;
Buffer instanceBuffer = Buffer(
*VulkanContext::get()->m_logicalDevice,
sizeof(instance),
vk::BufferUsageFlagBits::eShaderDeviceAddress
| vk::BufferUsageFlagBits::eTransferDst,
"Top AS instance buffer",
std::vector<vk::AccelerationStructureInstanceKHR> instanceVec = { instance };
instanceBuffer.uploadToBuffer(instanceVec);
vk::DeviceOrHostAddressConstKHR instanceAddress;
instanceAddress.deviceAddress =
VulkanContext::get()->m_logicalDevice->getBufferAddress(instanceBuffer.get());
geometry.geometryType = vk::GeometryTypeKHR::eInstances;
geometry.geometry.instances.arrayOfPointers = VK_FALSE;
geometry.geometry.instances.data = &instanceAddress.deviceAddress;
vk::AccelerationStructureGeometryKHR* pGeometry = &geometry;
*as.structure,
"Top AS scratch buffer");
vk::AccelerationStructureBuildGeometryInfoKHR geometryInfo;
geometryInfo.type = vk::AccelerationStructureTypeKHR::eTopLevel;
geometryInfo.flags = vk::BuildAccelerationStructureFlagBitsKHR::ePreferFastTrace;
geometryInfo.update = VK_FALSE;
geometryInfo.srcAccelerationStructure = nullptr;
geometryInfo.dstAccelerationStructure = *as.structure;
geometryInfo.geometryArrayOfPointers = VK_FALSE;
geometryInfo.geometryCount = 1;
geometryInfo.ppGeometries = &pGeometry;
geometryInfo.scratchData.deviceAddress =
offsetInfo.primitiveCount = 1;
computeCmdBuffer->get().buildAccelerationStructureKHR(1, &geometryInfo, &pOffsetInfo);
return as;
Buffer AccelerationStructures::createScratchBuffer(
vk::AccelerationStructureKHR& accelerationStructure,
vk::AccelerationStructureMemoryRequirementsTypeKHR type,
std::string name) {
memoryInfo.type = type;
memoryInfo.accelerationStructure = accelerationStructure;
return Buffer(
memoryRequirements.size,
vk::BufferUsageFlagBits::eRayTracingKHR
| vk::BufferUsageFlagBits::eShaderDeviceAddress,
name,
getBufferDeviceAddress is a template:
template <class T>
T getBufferDeviceAddress(vk::Buffer& buffer) {
vk::BufferDeviceAddressInfo addressInfo;
addressInfo.buffer = buffer;
return { VulkanContext::get()->m_logicalDevice->getBufferAddress(addressInfo) };
I’m out of options, I don’t know how to resolve this, I have no idea why would the TLAS build succeed, but then crash everything else. It’s even more peculiar since BLAS build uses identical process as TLAS build for the most part.
OS: Win10
Driver: 443.15 beta
