I’m trying to use bpnet from tlt. I loged in to docker and NGC both in virtualenv terminal and user terminal. Also when I tried to download nvidia-docker I get
2021-07-04 13:49:38,967 [INFO] root: Registry: ['nvcr.io']
2021-07-04 13:49:39,377 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the ~/.tlt_mounts.json file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Error response from daemon: Container 058772c954ca968af3103c72ee9218642419e4a404ac70e9132909a459a04951 is not running
2021-07-04 13:49:48,171 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
File "/home/inovako/tlt/lib/python3.6/site-packages/docker/api/client.py", line 259, in _raise_for_status
response.raise_for_status()
File "/home/inovako/tlt/lib/python3.6/site-packages/requests/models.py", line 941, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: http+docker://localhost/v1.41/containers/058772c954ca968af3103c72ee9218642419e4a404ac70e9132909a459a04951/stop
During handling of the above exception, another exception occurred:
File "/home/inovako/tlt/bin/tlt", line 8, in <module>
sys.exit(main())
File "/home/inovako/tlt/lib/python3.6/site-packages/tlt/entrypoint/entrypoint.py", line 114, in main
args[1:]
File "/home/inovako/tlt/lib/python3.6/site-packages/tlt/components/instance_handler/local_instance.py", line 278, in launch_command
docker_handler.run_container(command)
File "/home/inovako/tlt/lib/python3.6/site-packages/tlt/components/docker_handler/docker_handler.py", line 299, in run_container
self.stop_container()
File "/home/inovako/tlt/lib/python3.6/site-packages/tlt/components/docker_handler/docker_handler.py", line 306, in stop_container
self._container.stop()
File "/home/inovako/tlt/lib/python3.6/site-packages/docker/models/containers.py", line 436, in stop
return self.client.api.stop(self.id, **kwargs)
File "/home/inovako/tlt/lib/python3.6/site-packages/docker/utils/decorators.py", line 19, in wrapped
return f(self, resource_id, *args, **kwargs)
File "/home/inovako/tlt/lib/python3.6/site-packages/docker/api/container.py", line 1167, in stop
self._raise_for_status(res)
File "/home/inovako/tlt/lib/python3.6/site-packages/docker/api/client.py", line 261, in _raise_for_status
raise create_api_error_from_http_exception(e)
File "/home/inovako/tlt/lib/python3.6/site-packages/docker/errors.py", line 31, in create_api_error_from_http_exception
raise cls(e, response=response, explanation=explanation)
docker.errors.NotFound: 404 Client Error: Not Found ("No such container: 058772c954ca968af3103c72ee9218642419e4a404ac70e9132909a459a04951")
And TLT info is
Configuration of the TLT Instance
dockers: [‘nvidia/tlt-streamanalytics’, ‘nvidia/tlt-pytorch’]
format_version: 1.0
tlt_version: 3.0
published_date: 04/16/2021
