I’m running the mask_rcnn.ipynb from TLT and once I launch the command: “!tlt mask_rcnn run bash $SPECS_DIR/download_and_preprocess_coco.sh $DATA_DOWNLOAD_DIR”, I receive the error: “Error response from daemon: Container 1274985188bb12f11706234adde035ba2afd6381ec5eeb431dab550a07a3c4da is not running
2021-04-13 09:16:17,364 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.”
I have defined all the variables before launching this command and I have followed the guide to configure my jetson nano, but this problem is new to me.
INFORMATION:
nvidia-container info:
– WARNING, the following logs are for debugging purposes only –
I0413 07:37:21.396178 9465 nvc.c:281] initializing library context (version=0.9.0+beta1, build=77c1cbc2f6595c59beda3699ebb9d49a0a8af426)
I0413 07:37:21.396418 9465 nvc.c:255] using root /
I0413 07:37:21.396456 9465 nvc.c:256] using ldcache /etc/ld.so.cache
I0413 07:37:21.396502 9465 nvc.c:257] using unprivileged user 1000:1000
I0413 07:37:21.397213 9467 driver.c:134] starting driver service
I0413 07:37:21.420778 9465 nvc_info.c:585] requesting driver information with ‘’
I0413 07:37:21.421761 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-tls.so.32.5.1
I0413 07:37:21.421903 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-ptxjitcompiler.so.440.18
I0413 07:37:21.422018 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glsi.so.32.5.1
I0413 07:37:21.422123 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glcore.so.32.5.1
I0413 07:37:21.422226 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.440.18
I0413 07:37:21.422337 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.32.5.1
I0413 07:37:21.423126 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1
I0413 07:37:21.423637 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libGLX_nvidia.so.0
I0413 07:37:21.423752 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2
I0413 07:37:21.423858 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv1_CM_nvidia.so.1
I0413 07:37:21.423974 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0
W0413 07:37:21.424065 9465 nvc_info.c:305] missing library libnvidia-ml.so
W0413 07:37:21.424085 9465 nvc_info.c:305] missing library libnvidia-cfg.so
W0413 07:37:21.424104 9465 nvc_info.c:305] missing library libnvidia-opencl.so
W0413 07:37:21.424117 9465 nvc_info.c:305] missing library libnvidia-compiler.so
W0413 07:37:21.424137 9465 nvc_info.c:305] missing library libvdpau_nvidia.so
W0413 07:37:21.424157 9465 nvc_info.c:305] missing library libnvidia-encode.so
W0413 07:37:21.424172 9465 nvc_info.c:305] missing library libnvcuvid.so
W0413 07:37:21.424189 9465 nvc_info.c:305] missing library libnvidia-fbc.so
W0413 07:37:21.424204 9465 nvc_info.c:305] missing library libnvidia-ifr.so
W0413 07:37:21.424215 9465 nvc_info.c:309] missing compat32 library libnvidia-ml.so
W0413 07:37:21.424229 9465 nvc_info.c:309] missing compat32 library libnvidia-cfg.so
W0413 07:37:21.424247 9465 nvc_info.c:309] missing compat32 library libcuda.so
W0413 07:37:21.424264 9465 nvc_info.c:309] missing compat32 library libnvidia-opencl.so
W0413 07:37:21.424286 9465 nvc_info.c:309] missing compat32 library libnvidia-ptxjitcompiler.so
W0413 07:37:21.424306 9465 nvc_info.c:309] missing compat32 library libnvidia-fatbinaryloader.so
W0413 07:37:21.424324 9465 nvc_info.c:309] missing compat32 library libnvidia-compiler.so
W0413 07:37:21.424338 9465 nvc_info.c:309] missing compat32 library libvdpau_nvidia.so
W0413 07:37:21.424358 9465 nvc_info.c:309] missing compat32 library libnvidia-encode.so
W0413 07:37:21.424376 9465 nvc_info.c:309] missing compat32 library libnvcuvid.so
W0413 07:37:21.424391 9465 nvc_info.c:309] missing compat32 library libnvidia-eglcore.so
W0413 07:37:21.424406 9465 nvc_info.c:309] missing compat32 library libnvidia-glcore.so
W0413 07:37:21.424420 9465 nvc_info.c:309] missing compat32 library libnvidia-tls.so
W0413 07:37:21.424437 9465 nvc_info.c:309] missing compat32 library libnvidia-glsi.so
W0413 07:37:21.424452 9465 nvc_info.c:309] missing compat32 library libnvidia-fbc.so
W0413 07:37:21.424468 9465 nvc_info.c:309] missing compat32 library libnvidia-ifr.so
W0413 07:37:21.424482 9465 nvc_info.c:309] missing compat32 library libGLX_nvidia.so
W0413 07:37:21.424498 9465 nvc_info.c:309] missing compat32 library libEGL_nvidia.so
W0413 07:37:21.424517 9465 nvc_info.c:309] missing compat32 library libGLESv2_nvidia.so
W0413 07:37:21.424536 9465 nvc_info.c:309] missing compat32 library libGLESv1_CM_nvidia.so
W0413 07:37:21.426872 9465 nvc_info.c:331] missing binary nvidia-smi
W0413 07:37:21.426903 9465 nvc_info.c:331] missing binary nvidia-debugdump
W0413 07:37:21.426926 9465 nvc_info.c:331] missing binary nvidia-persistenced
W0413 07:37:21.426945 9465 nvc_info.c:331] missing binary nvidia-cuda-mps-control
W0413 07:37:21.426965 9465 nvc_info.c:331] missing binary nvidia-cuda-mps-server
W0413 07:37:21.427047 9465 nvc_info.c:280] missing ipc /var/run/nvidia-persistenced/socket
W0413 07:37:21.427119 9465 nvc_info.c:280] missing ipc /tmp/nvidia-mps
I0413 07:37:21.427525 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn.so.8.0.0
I0413 07:37:21.427636 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_ops_infer.so.8.0.0
I0413 07:37:21.427739 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_ops_train.so.8.0.0
I0413 07:37:21.427840 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_adv_infer.so.8.0.0
I0413 07:37:21.427951 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_cnn_infer.so.8.0.0
I0413 07:37:21.428061 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_adv_train.so.8.0.0
I0413 07:37:21.428164 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_cnn_train.so.8.0.0
I0413 07:37:21.428265 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_adv_infer_v8.h
I0413 07:37:21.428359 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_adv_train_v8.h
I0413 07:37:21.428443 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_backend_v8.h
I0413 07:37:21.428531 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_cnn_infer_v8.h
I0413 07:37:21.428620 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_cnn_train_v8.h
I0413 07:37:21.428710 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_ops_infer_v8.h
I0413 07:37:21.428804 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_ops_train_v8.h
I0413 07:37:21.428888 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_v8.h
I0413 07:37:21.428974 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_version_v8.h
I0413 07:37:21.429060 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/cudnn_v8.h
I0413 07:37:21.429159 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_adv_infer.so.8.0.0
I0413 07:37:21.429271 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_adv_infer_static_v8.a
I0413 07:37:21.429413 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_adv_train.so.8.0.0
I0413 07:37:21.429527 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_adv_train_static_v8.a
I0413 07:37:21.429637 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_cnn_infer.so.8.0.0
I0413 07:37:21.429751 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_cnn_infer_static_v8.a
I0413 07:37:21.429864 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_cnn_train.so.8.0.0
I0413 07:37:21.429973 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_cnn_train_static_v8.a
I0413 07:37:21.430087 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_ops_infer.so.8.0.0
I0413 07:37:21.430201 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_ops_infer_static_v8.a
I0413 07:37:21.430311 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_ops_train.so.8.0.0
I0413 07:37:21.430414 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_ops_train_static_v8.a
I0413 07:37:21.430524 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn.so.8.0.0
I0413 07:37:21.430632 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcudnn_static_v8.a
I0413 07:37:21.431108 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libnvinfer.so.7.1.3
I0413 07:37:21.431222 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.1.3
I0413 07:37:21.431322 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libnvparsers.so.7.1.3
I0413 07:37:21.431430 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libnvonnxparser.so.7.1.3
I0413 07:37:21.431532 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libmyelin.so.1.1.0
I0413 07:37:21.431633 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvInfer.h
I0413 07:37:21.431732 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvInferRuntime.h
I0413 07:37:21.431829 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvInferRuntimeCommon.h
I0413 07:37:21.431922 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvInferVersion.h
I0413 07:37:21.432007 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvUtils.h
I0413 07:37:21.432093 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvInferPlugin.h
I0413 07:37:21.432182 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvInferPluginUtils.h
I0413 07:37:21.432268 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvCaffeParser.h
I0413 07:37:21.432353 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvUffParser.h
I0413 07:37:21.432438 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvOnnxConfig.h
I0413 07:37:21.432529 9465 nvc_info.c:154] selecting /usr/include/aarch64-linux-gnu/NvOnnxParser.h
I0413 07:37:21.433073 9465 nvc_info.c:154] selecting /usr/lib/libvisionworks_sfm.so.0.90.4
I0413 07:37:21.433171 9465 nvc_info.c:154] selecting /usr/lib/libvisionworks.so.1.6.0
I0413 07:37:21.433264 9465 nvc_info.c:154] selecting /usr/lib/libvisionworks_tracking.so.0.88.2
I0413 07:37:21.433892 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvv4l2.so
I0413 07:37:21.434015 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/desktop-shell.so
I0413 07:37:21.434127 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/drm-backend.so
I0413 07:37:21.434235 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/EGLWLInputEventExample
I0413 07:37:21.434345 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/EGLWLMockNavigation
I0413 07:37:21.434449 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/fullscreen-shell.so
I0413 07:37:21.434557 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/gl-renderer.so
I0413 07:37:21.434665 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/hmi-controller.so
I0413 07:37:21.434777 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/ivi-controller.so
I0413 07:37:21.434883 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/ivi-shell.so
I0413 07:37:21.434995 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/LayerManagerControl
I0413 07:37:21.435101 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/libilmClient.so.2.2.0
I0413 07:37:21.435205 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/libilmCommon.so.2.2.0
I0413 07:37:21.435309 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/libilmControl.so.2.2.0
I0413 07:37:21.435416 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/libilmInput.so.2.2.0
I0413 07:37:21.435521 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/libweston-6.so.0
I0413 07:37:21.435634 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/libweston-desktop-6.so.0
I0413 07:37:21.435743 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/simple-weston-client
I0413 07:37:21.435846 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/spring-tool
I0413 07:37:21.435953 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/wayland-backend.so
I0413 07:37:21.436067 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston
I0413 07:37:21.436178 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-calibrator
I0413 07:37:21.436288 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-clickdot
I0413 07:37:21.436396 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-cliptest
I0413 07:37:21.436509 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-content-protection
I0413 07:37:21.436614 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-debug
I0413 07:37:21.436723 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-desktop-shell
I0413 07:37:21.436832 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-dnd
I0413 07:37:21.436944 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-eventdemo
I0413 07:37:21.437053 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-flower
I0413 07:37:21.437164 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-fullscreen
I0413 07:37:21.437273 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-image
I0413 07:37:21.437408 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-info
I0413 07:37:21.437517 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-ivi-shell-user-interface
I0413 07:37:21.437629 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-keyboard
I0413 07:37:21.437734 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-launch
I0413 07:37:21.437838 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-multi-resource
I0413 07:37:21.437946 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-output-mode
I0413 07:37:21.438054 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-resizor
I0413 07:37:21.438164 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-scaler
I0413 07:37:21.438270 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-screenshooter
I0413 07:37:21.438379 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-dmabuf-egldevice
I0413 07:37:21.438490 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-egl
I0413 07:37:21.438597 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-shm
I0413 07:37:21.438701 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-touch
I0413 07:37:21.438805 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-smoke
I0413 07:37:21.438915 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-stacking
I0413 07:37:21.439025 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-subsurfaces
I0413 07:37:21.439133 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-terminal
I0413 07:37:21.439244 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/weston/weston-transformed
I0413 07:37:21.439352 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
I0413 07:37:21.439454 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so
I0413 07:37:21.439553 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvdrmvideosink.so
I0413 07:37:21.439660 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so
I0413 07:37:21.439762 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so
I0413 07:37:21.439860 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so
I0413 07:37:21.439960 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so
I0413 07:37:21.440064 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so
I0413 07:37:21.440161 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvtee.so
I0413 07:37:21.440261 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so
I0413 07:37:21.440364 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so
I0413 07:37:21.440469 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
I0413 07:37:21.440574 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideocuda.so
I0413 07:37:21.440675 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so
I0413 07:37:21.440781 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so
I0413 07:37:21.440882 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstomx.so
I0413 07:37:21.440975 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libgstnvegl-1.0.so.0
I0413 07:37:21.441066 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libgstnvexifmeta.so
I0413 07:37:21.441152 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libgstnvivameta.so
I0413 07:37:21.441246 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libnvsample_cudaprocess.so
I0413 07:37:21.441374 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf
I0413 07:37:21.441474 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0
I0413 07:37:21.441586 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv1_CM_nvidia.so.1
I0413 07:37:21.441687 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2
I0413 07:37:21.441788 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra-egl/nvidia.json
I0413 07:37:21.441887 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1
I0413 07:37:21.441990 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libdrm.so.2
I0413 07:37:21.442095 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libGLX_nvidia.so.0
I0413 07:37:21.442196 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvapputil.so
I0413 07:37:21.442297 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvargus.so
I0413 07:37:21.442403 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvargus_socketclient.so
I0413 07:37:21.442519 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvargus_socketserver.so
I0413 07:37:21.442620 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvavp.so
I0413 07:37:21.442716 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_fdmap.so.1.0.0
I0413 07:37:21.442816 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so.1.0.0
I0413 07:37:21.442922 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0
I0413 07:37:21.443030 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so.1.0.0
I0413 07:37:21.443134 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvcameratools.so
I0413 07:37:21.443242 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvcamerautils.so
I0413 07:37:21.443346 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvcam_imageencoder.so
I0413 07:37:21.443447 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvcamlog.so
I0413 07:37:21.443548 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvcamv4l2.so
I0413 07:37:21.443648 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvcolorutil.so
I0413 07:37:21.443751 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvdc.so
I0413 07:37:21.443852 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvddk_2d_v2.so
I0413 07:37:21.443958 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvddk_vic.so
I0413 07:37:21.444057 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvdecode2eglimage.so
I0413 07:37:21.444161 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvdla_compiler.so
I0413 07:37:21.444267 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvdla_runtime.so
I0413 07:37:21.444371 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so.1.0.0
I0413 07:37:21.444467 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnveglstream_camconsumer.so
I0413 07:37:21.444564 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnveglstreamproducer.so
I0413 07:37:21.444661 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnveventlib.so
I0413 07:37:21.444752 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvexif.so
I0413 07:37:21.444854 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvfnet.so
I0413 07:37:21.444955 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvfnetstoredefog.so
I0413 07:37:21.445059 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvfnetstorehdfx.so
I0413 07:37:21.445160 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgbm.so
I0413 07:37:21.445256 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_boot.so
I0413 07:37:21.445381 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_camera.so
I0413 07:37:21.445482 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_force.so
I0413 07:37:21.445579 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_generic.so
I0413 07:37:21.445670 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_gpucompute.so
I0413 07:37:21.445763 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_graphics.so
I0413 07:37:21.445855 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_il.so
I0413 07:37:21.445951 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_spincircle.so
I0413 07:37:21.446046 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_tbc.so
I0413 07:37:21.446138 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvgov_ui.so
I0413 07:37:21.446243 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.32.5.1
I0413 07:37:21.446349 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-wayland.so
I0413 07:37:21.446457 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.440.18
I0413 07:37:21.446557 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glcore.so.32.5.1
I0413 07:37:21.446661 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glsi.so.32.5.1
I0413 07:37:21.446769 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glvkspirv.so.32.5.1
I0413 07:37:21.446882 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-ptxjitcompiler.so.440.18
I0413 07:37:21.446992 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-rmapi-tegra.so.32.5.1
I0413 07:37:21.447111 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvidia-tls.so.32.5.1
I0413 07:37:21.447217 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvid_mapper.so.1.0.0
I0413 07:37:21.447311 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvimp.so
I0413 07:37:21.447414 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so
I0413 07:37:21.447514 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvll.so
I0413 07:37:21.447616 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvmedia.so
I0413 07:37:21.447720 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvmm_contentpipe.so
I0413 07:37:21.447820 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_image.so
I0413 07:37:21.447919 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite.so
I0413 07:37:21.448013 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_utils.so
I0413 07:37:21.448112 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so
I0413 07:37:21.448215 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvmm_parser.so
I0413 07:37:21.448314 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvmm.so
I0413 07:37:21.448412 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvmm_utils.so
I0413 07:37:21.448516 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvodm_imager.so
I0413 07:37:21.448625 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvofsdk.so
I0413 07:37:21.448727 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvomxilclient.so
I0413 07:37:21.448830 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvomx.so
I0413 07:37:21.448929 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvosd.so
I0413 07:37:21.449028 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvos.so
I0413 07:37:21.449130 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvparser.so
I0413 07:37:21.449231 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvphsd.so
I0413 07:37:21.449562 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvphs.so
I0413 07:37:21.449670 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so
I0413 07:37:21.449778 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvrm_graphics.so
I0413 07:37:21.449881 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvrm.so
I0413 07:37:21.449989 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvscf.so
I0413 07:37:21.450093 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvtestresults.so
I0413 07:37:21.450187 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvtnr.so
I0413 07:37:21.450281 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvtracebuf.so
I0413 07:37:21.450381 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvtvmr.so
I0413 07:37:21.450483 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvv4l2.so
I0413 07:37:21.450588 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvv4lconvert.so
I0413 07:37:21.450687 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvvulkan-producer.so
I0413 07:37:21.450785 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libnvwinsys.so
I0413 07:37:21.450886 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libsensors.hal-client.nvs.so
I0413 07:37:21.450992 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libsensors_hal.nvs.so
I0413 07:37:21.451091 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libsensors.l4t.no_fusion.nvs.so
I0413 07:37:21.451191 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libtegrav4l2.so
I0413 07:37:21.451293 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvargus.so
I0413 07:37:21.451392 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvvidconv.so
I0413 07:37:21.451490 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvvideocodec.so
I0413 07:37:21.451588 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/libvulkan.so.1.2.141
I0413 07:37:21.451686 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/tegra/nvidia_icd.json
I0413 07:37:21.451785 9465 nvc_info.c:154] selecting /lib/firmware/tegra21x/nvhost_nvdec020_ns.fw
W0413 07:37:21.451870 9465 nvc_info.c:403] missing directory /lib/firmware/tegra19x
W0413 07:37:21.451930 9465 nvc_info.c:403] missing directory /lib/firmware/tegra18x
W0413 07:37:21.452214 9465 nvc_info.c:459] missing device /dev/nvhost-nvdec1
W0413 07:37:21.452319 9465 nvc_info.c:459] missing device /dev/nvhost-ctrl-nvdla0
W0413 07:37:21.452375 9465 nvc_info.c:459] missing device /dev/nvhost-ctrl-nvdla1
W0413 07:37:21.452428 9465 nvc_info.c:459] missing device /dev/nvhost-nvdla0
W0413 07:37:21.452480 9465 nvc_info.c:459] missing device /dev/nvhost-nvdla1
W0413 07:37:21.452531 9465 nvc_info.c:459] missing device /dev/nvidiactl
W0413 07:37:21.452705 9465 nvc_info.c:459] missing device /dev/nvhost-nvenc1
I0413 07:37:21.453092 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcublas.so.10.2.2.89
I0413 07:37:21.453208 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libcublasLt.so.10.2.2.89
I0413 07:37:21.453326 9465 nvc_info.c:154] selecting /usr/lib/aarch64-linux-gnu/libnvblas.so.10.2.2.89
I0413 07:37:21.453418 9465 nvc_info.c:154] selecting /usr/include/cublas_api.h
I0413 07:37:21.453502 9465 nvc_info.c:154] selecting /usr/include/cublasLt.h
I0413 07:37:21.453584 9465 nvc_info.c:154] selecting /usr/include/cublasXt.h
I0413 07:37:21.453667 9465 nvc_info.c:154] selecting /usr/include/cublas.h
I0413 07:37:21.453747 9465 nvc_info.c:154] selecting /usr/include/cublas_v2.h
W0413 07:37:21.453841 9465 nvc_info.c:431] missing symlink /usr/loca/cuda
I0413 07:37:21.453950 9465 nvc_info.c:642] requesting device information with opts: ‘’
I0413 07:37:21.454359 9465 nvc_info.c:660] listing device (null) ((null) at (null))
NVRM version: (null)
CUDA version: 10.2
Device Index: 0
Device Minor: 0
Model: NVIDIA Tegra X1
Brand: (null)
GPU UUID: (null)
Bus Location: (null)
Architecture: 5.3
I0413 07:37:21.454471 9465 nvc.c:314] shutting down library context
I0413 07:37:21.454546 9467 driver.c:191] terminating driver service
I0413 07:37:21.455464 9465 driver.c:231] driver service terminated successfully
kernel version:
Linux aqc-desktop 4.9.201-tegra #1 SMP PREEMPT Fri Feb 19 08:40:32 PST 2021 aarch64 aarch64 aarch64 GNU/Linux
Docker information:
Client:
Version: 19.03.6
API version: 1.40
Go version: go1.12.17
Git commit: 369ce74a3c
Built: Fri Dec 18 12:25:49 2020
OS/Arch: linux/arm64
Experimental: false
Server:
Engine:
Version: 19.03.6
API version: 1.40 (minimum version 1.12)
Built: Thu Dec 10 13:23:49 2020
Experimental: false
containerd:
Version: 1.3.3-0ubuntu1~18.04.4
GitCommit:
runc:
Version: spec: 1.0.1-dev
GitCommit:
docker-init:
Version: 0.18.0
GitCommit:
