I am trying to run the tlt augment command inside the tlt container, but got the following error:
Command used to run the container is :
sudo docker run --gpus all -it -v /workspace/tlt-experiments/:/workspace/tlt-experiments -p 8888:8888 nvcr.io/nvidia/tlt-streamanalytics:v3.0-py3 /bin/bash
root@1833e5376a0d:/workspace/tlt-experiments# tlt augment -d /workspace/tlt-experiments/data/training/ -a /workspace/tlt-experiments/specs/default_spec.txt -o /workspace/tlt-experiments/augment -v
2021-07-03 13:29:50,128 [INFO] root: Registry: [‘nvcr.io’]
** File “/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py”, line 677, in urlopen**
** chunked=chunked,**
** File “/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py”, line 392, in _make_request**
** conn.request(method, url, httplib_request_kw)
** File “/usr/lib/python3.6/http/client.py”, line 1281, in request**
** self._send_request(method, url, body, headers, encode_chunked)**
** File “/usr/lib/python3.6/http/client.py”, line 1327, in _send_request**
** self.endheaders(body, encode_chunked=encode_chunked)**
** File “/usr/lib/python3.6/http/client.py”, line 1276, in endheaders**
** self._send_output(message_body, encode_chunked=encode_chunked)**
** File “/usr/lib/python3.6/http/client.py”, line 1042, in _send_output**
** self.send(msg)**
** File “/usr/lib/python3.6/http/client.py”, line 980, in send**
** self.connect()**
** File “/usr/local/lib/python3.6/dist-packages/docker/transport/unixconn.py”, line 43, in connect**
** sock.connect(self.unix_socket)**
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
** File “/usr/local/lib/python3.6/dist-packages/requests/adapters.py”, line 449, in send**
** timeout=timeout**
** File “/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py”, line 727, in urlopen**
** method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]**
** File “/usr/local/lib/python3.6/dist-packages/urllib3/util/retry.py”, line 403, in increment**
** raise six.reraise(type(error), error, _stacktrace)**
** File “/usr/local/lib/python3.6/dist-packages/urllib3/packages/six.py”, line 734, in reraise**
** raise value.with_traceback(tb)**
** self.send(msg)**
** self.connect()**
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
** File “/usr/local/lib/python3.6/dist-packages/docker/api/client.py”, line 205, in _retrieve_server_version**
** return self.version(api_version=False)[“ApiVersion”]**
** File “/usr/local/lib/python3.6/dist-packages/docker/api/daemon.py”, line 181, in version**
** return self._result(self._get(url), json=True)**
** File “/usr/local/lib/python3.6/dist-packages/docker/utils/decorators.py”, line 46, in inner**
** return f(self, args, kwargs)
** File “/usr/local/lib/python3.6/dist-packages/docker/api/client.py”, line 228, in _get*
** return self.get(url, self._set_request_timeout(kwargs))
** File “/usr/local/lib/python3.6/dist-packages/requests/sessions.py”, line 543, in get**
** return self.request(‘GET’, url, kwargs)
** File “/usr/local/lib/python3.6/dist-packages/requests/sessions.py”, line 530, in request**
** resp = self.send(prep, send_kwargs)
** File “/usr/local/lib/python3.6/dist-packages/requests/sessions.py”, line 643, in send**
** r = adapter.send(request, kwargs)
** File “/usr/local/lib/python3.6/dist-packages/requests/adapters.py”, line 498, in send**
** raise ConnectionError(err, request=request)**
requests.exceptions.ConnectionError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
** File “/usr/local/bin/tlt”, line 8, in **
** sys.exit(main())**
** File “/usr/local/lib/python3.6/dist-packages/tlt/entrypoint/entrypoint.py”, line 114, in main**
** args[1:]**
** File “/usr/local/lib/python3.6/dist-packages/tlt/components/instance_handler/local_instance.py”, line 259, in launch_command**
** docker_handler = self.handler_map[**
** File “/usr/local/lib/python3.6/dist-packages/tlt/components/instance_handler/local_instance.py”, line 114, in handler_map**
** docker_mount_file=os.getenv(“LAUNCHER_MOUNTS”, DOCKER_MOUNT_FILE)**
** File “/usr/local/lib/python3.6/dist-packages/tlt/components/docker_handler/docker_handler.py”, line 47, in init**
** self._docker_client = docker.from_env()**
** File “/usr/local/lib/python3.6/dist-packages/docker/client.py”, line 85, in from_env**
** timeout=timeout, version=version, kwargs_from_env(kwargs)
** File “/usr/local/lib/python3.6/dist-packages/docker/client.py”, line 40, in init
** self.api = APIClient(args, kwargs)
** File “/usr/local/lib/python3.6/dist-packages/docker/api/client.py”, line 188, in init*
** self._version = self._retrieve_server_version()**
** File “/usr/local/lib/python3.6/dist-packages/docker/api/client.py”, line 213, in _retrieve_server_version**
** ‘Error while fetching server API version: {0}’.format(e)**
docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
Content inside the /workspace/tlt-experiments/ directory is as follows:
root@1833e5376a0d:/workspace/tlt-experiments# ls
augment.ipynb data specs
Specification file content is:
root@1833e5376a0d:/workspace/tlt-experiments# cat specs/default_spec.txt **
# Spec file for tlt-augment.
spatial_config{
** rotation_config{
** angle: 10.0**
** units: “degrees”**
dataset_config{
** image_path: “image_2”**
** label_path: “label_2”**
color_config{
** hue_saturation_config{**
** hue_rotation_angle: 5.0**
** saturation_shift: 1.0**
output_image_width: 1248
output_image_height: 384
output_image_channel: 3
and data is as follows:
image_extension: ".png"root@1833e5376a0d:/workspace/tlt-experiments# ls data/
testing training
root@1833e5376a0d:/workspace/tlt-experiments# ls data/training/
image_2 label_2
currently i am just trying to run the augmentation using tlt on the dataset
