I am trying to augment my data using the offline data augmentation tool. But I am getting an unknown error and the logs are not helping at all.
I have narrowed down my images folder to augment, to only two items to try to find the issue but I am getting the same error:
tao augment -d /workspace/tlt-experiments/data/images -a /workspace/tlt-experiments/data/augment_spec.yml -o /workspace/tlt-experiments/data/images_augmented -v
2023-04-18 07:20:18,493 [INFO] root: Registry: ['nvcr.io']
2023-04-18 07:20:18,601 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
2023-04-18 07:20:18,623 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/ubuntu/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
2023-04-18 07:20:19.955817: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
2023-04-18 07:20:22,196 [INFO] iva.augment.spec_handler.spec_loader: Merging specification from /workspace/tlt-experiments/data/augment_spec.yml
2023-04-18 07:20:22,198 [INFO] iva.augment.scripts.augment: Serializing augmentation spec
spatial_config {
rotation_config {
angle: 10.0
units: "degrees"
output_image_width: 720
output_image_height: 720
output_image_channel: 3
image_extension: ".jpg"
2023-04-18 07:20:22,234 [INFO] iva.augment.scripts.augment: Listing files in the dataset.
2023-04-18 07:20:22,235 [DEBUG] iva.augment.scripts.augment: Time taken to list kitti files: 0.00115966796875
2023-04-18 07:20:22,236 [INFO] iva.augment.scripts.augment: Preparing file fetchers for augmentation.
2023-04-18 07:20:22,236 [DEBUG] iva.augment.scripts.augment: Defining the pipeline.
2023-04-18 07:20:22,243 [DEBUG] iva.augment.scripts.augment: Building the pipeline.
Augmentation run failed with error: Critical error when building pipeline:
Error when constructing operator: ImageDecoder encountered:
std::bad_alloc
Current pipeline object is no longer valid.
2023-04-18 07:20:23,560 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Any idea of what’s wrong?
Find attach the spec file, and the folder structure.
• TLT Version: 4.0.1
augment_spec.yml (177 Bytes)
