I’ve looked into the source code for model training here
A few things:
I receive an error in my docker container when I run dataloader.get_dataset_tensors:
NotFoundError: in converted code:
/workspace/tao-tf1/third_party/keras/tensorflow_backend.py:365 _map_func_set_random_wrapper *
return map_func(*args, **kwargs)
/workspace/tao-tf1/nvidia_tao_tf1/cv/detectnet_v2/dataloader/drivenet_dataloader.py:174 __call__ *
labels = self._extract_bbox_labels(example)
/workspace/tao-tf1/nvidia_tao_tf1/cv/detectnet_v2/dataloader/drivenet_dataloader.py:265 _extract_bbox_labels *
sparse_coordinates = \
/workspace/tao-tf1/nvidia_tao_tf1/blocks/multi_source_loader/types/tensor_transforms.py:171 sparsify_dense_coordinates *
regular_sparse_tensor = values_and_count_to_sparse_tensor(
/workspace/tao-tf1/nvidia_tao_tf1/core/processors/processors.py:328 values_and_count_to_sparse_tensor *
op = load_custom_tf_op("op_values_and_count_to_sparse_tensor.so")
/workspace/tao-tf1/nvidia_tao_tf1/core/processors/processors.py:201 load_custom_tf_op
return tf.load_op_library(abs_path)
/usr/local/lib/python3.8/dist-packages/tensorflow_core/python/framework/load_library.py:61 load_op_library
lib_handle = py_tf.TF_LoadLibrary(library_filename)
NotFoundError: /workspace/tao-tf1/nvidia_tao_tf1/core/processors/../lib/op_values_and_count_to_sparse_tensor.so: cannot open shared object file: No such file or directory
I’m in a docker container launched with (launcher) ubuntu@ip-172-31-6-30:~/tao_tensorflow1_backend$ tao_tf --gpus all --port 8888:8888. I’ve met all of the software requirements (including nvidia-container-toolkit installed). It looks like there is an issue with the tensorflow image but I’m not sure how to solve the issue.
This is the moment we receive images/labels for model training. I’ve explored the dataloader class but I’m getting a bit lost. Would it make sense to apply albumentations somwhere in dataloader or after we receive images/labels from this class?
Please develop your custom augmentations inside the TAO docker. After that, you can docker commit to save your changes.
BTW, the lib is available as below.
root@c038ddb07924:/usr/local/lib/python3.8/dist-packages# ls ./nvidia_tao_tf1/core/lib/op_values_and_count_to_sparse_tensor.so
