• Hardware (T4/V100/Xavier/Nano/etc)
Ubuntu 20.04.3 LTS x64 , RTX3090
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
Classification
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
!tao info
dockers: [‘nvidia/tao/tao-toolkit-tf’, ‘nvidia/tao/tao-toolkit-pyt’, ‘nvidia/tao/tao-toolkit-lm’]
format_version: 2.0
toolkit_version: 3.21.11
published_date: 11/08/2021
• Training spec file(If have, please share here)
model_config {
arch: "resnet",
n_layers: 50
# Setting these parameters to true to match the template downloaded from NGC.
use_batch_norm: true
all_projections: true
freeze_blocks: 0
freeze_blocks: 1
input_image_size: "3,224,224"
train_config {
train_dataset_path: "/workspace/tao-experiments/data/split/train"
val_dataset_path: "/workspace/tao-experiments/data/split/val"
pretrained_model_path: "/workspace/tao-experiments/classification/pretrained_resnet50/pretrained_classification_vresnet50/resnet_50.hdf5"
optimizer {
sgd {
lr: 0.015
decay: 0.0
momentum: 0.9
nesterov: False
batch_size_per_gpu: 48
n_epochs: 120
n_workers: 16
preprocess_mode: "caffe"
enable_random_crop: True
enable_center_crop: True
label_smoothing: 0.0
mixup_alpha: 0.1
# regularizer
reg_config {
type: "L2"
scope: "Conv2D,Dense"
weight_decay: 0.00005
# learning_rate
lr_config {
step {
learning_rate: 0.009
step_size: 10
gamma: 0.1
eval_config {
eval_dataset_path: "/workspace/tao-experiments/data/split/test"
model_path: "/workspace/tao-experiments/classification/output/weights/resnet_120.tlt"
top_k: 3
batch_size: 256
n_workers: 8
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I noticed the accurate is surprisingly low when I test the sample image with upside down or other angle against the final trained model, but my training dataset does not cover those cases.
Question: Is there anyway in Training spec
that can enable these image angle Augmentation
