I am attempting to train the “ccpd_unpruned.tlt” pretrained model with this command:“tlt detectnet_v2 train --gpus=1 --gpu_index=0 -e /workspace/openalpr/specs/SPECS_train.txt -r /workspace/openalpr/exp_unpruned -k nvidia_tlt”
However, I am getting this error,but it’s ok to use “usa_unpruned.tlt” training.
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 260, in decode_to_keras
File “/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py”, line 417, in load_model
f = h5dict(filepath, ‘r’)
File “/usr/local/lib/python3.6/dist-packages/keras/utils/io_utils.py”, line 186, in init
self.data = h5py.File(path, mode=mode)
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 312, in init
fid = make_fid(name, mode, userblock_size, fapl, swmr=swmr)
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 142, in make_fid
fid = h5f.open(name, flags, fapl=fapl)
File “h5py/_objects.pyx”, line 54, in h5py._objects.with_phil.wrapper
File “h5py/_objects.pyx”, line 55, in h5py._objects.with_phil.wrapper
File “h5py/h5f.pyx”, line 78, in h5py.h5f.open
OSError: Unable to open file (file signature not found)
During handling of the above exception, another exception occurred:
OSError: Invalid decryption. Unable to open file (file signature not found). The key used to load the model is incorrect.
