2022-01-13 17:38:14,533 [INFO] root: Registry: [‘nvcr.io’]
2022-01-13 17:38:14,706 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.5-py3
2022-01-13 17:38:15,746 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/home/chenhongzhao/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
2022-01-13 09:38:18.074014: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
Using TensorFlow backend.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-01-13 09:38:22,304 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 312, in init
fid = make_fid(name, mode, userblock_size, fapl, swmr=swmr)
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 142, in make_fid
fid = h5f.open(name, flags, fapl=fapl)
File “h5py/_objects.pyx”, line 54, in h5py._objects.with_phil.wrapper
File “h5py/_objects.pyx”, line 55, in h5py._objects.with_phil.wrapper
File “h5py/h5f.pyx”, line 78, in h5py.h5f.open
OSError: Unable to open file (file signature not found)
During handling of the above exception, another exception occurred:
fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/utilities/tlt_utils.py", line 153, in decode_to_keras
OSError: Invalid decryption. Unable to open file (file signature not found). The key used to load the model is incorrect.
Running this project: “…/cv_samples_v1.3.0/bpnet” .
All the previous steps are OK until training
this is my API key:OXE5aDZnZmZpYmIwYW90OW12dTVlNXZzZTY6ZDgyYjZmYjItN2U3Yy00ODE5LWFhMmItY2YxZjUyYjM2NWVk
I try to use “tlt_encode”,no effect.
I have set.
docker login nvcr.io
Username: $oauthtoken
Password: OXE5aDZnZmZpYmIwYW90OW12dTVlNXZzZTY6ZDgyYjZmYjItN2U3Yy00ODE5LWFhMmItY2YxZjUyYjM2NWVk
please help me.
