Do you know if is it possible to modify the color of the bounding box generated by tlt-infer. Default one is black and it is not very visible.
I know also labels are saved as output so I can compose that in a different way, but I am a bit lazy :D
I can see the detectnet example you are pointing out, but it does not seem to me that those config structure in the protobuf works for the YOLO example which I am using. Even the documentation seems to suggest that the bbox_handler_config is only for the detectnet model. Is that correct or am I missing something?
Where should I put the bbox_color in the Yolo Config files?
