How to change bounding box color in run time?
I am using deepstream-app.
For example, class1 has red bounding box color in normal detection. But under certain condition, I like to change to green for class1. How can I do that?
Xavier
• DeepStream Version
5.1 (;atest)
R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020
• TensorRT Version
latest
10.2
Sorry for the late response, is this still an issue to support? Thanks
Yes still need to support
Can you refer below samples (Sample test application 1)? And check object_meta->rect_params if can change color?
C/C++ Sample Apps Source Details — DeepStream 6.0 Release documentation (nvidia.com)
That change color of all rectangles. But I like to change with ObjectMeta’s object_id. I like to change certain box only with that particular object_id. How can I do that?
I tried as
if(obj->object_id==0)
obj->rect_params.border_width = 30;
It doesn’t work.
There is no update for a period, assuming this is not an issue any more.
What is the status here? Is there still any issue?
