• Hardware Platform (Jetson / GPU) NVIDIA-Jetson-Orin-Nano-Developer-kit • DeepStream Version 6.3 • JetPack Version (valid for Jetson only) JetPack 5.1.2
Hello i’m trying to change the color of detected objects that are inside the region of interest in the deepstream-test5 , is there a way to implement this?
We have similar implementations in our open-source code that you can refer to. You can refer to the bbox-border-color0 field in the source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt file and the parsed code in the deepstream_config_file_parser.c.
I wanted to change the color of the bounding box everytime a detected object enters the roi, i have implemented inside the gie_processing_done_buf_prob Probe function, since i wasn’t able to add a probe directly in the deepstream-test5
if (appCtx[i]->config.dsanalytics_config.enable){
GstPad *src_pad = NULL;
GstElement *nvdosd = appCtx[i]->pipeline.common_elements.osd_bin.nvosd;
src_pad = gst_element_get_static_pad(nvdosd, "src");
if (!src_pad)
g_print ("Unable to get osd source pad\n");
else
gst_pad_add_probe (src_pad, GST_PAD_PROBE_TYPE_BUFFER,
osd_sink_pad_buffer_probe, NULL, NULL);
gst_object_unref (src_pad);
1)I was unable to get the osd pad, I think i might be working on the wrong pad?
2)Another question is there a way to access the detected objects inside the roi directly ? or do i have to compare the coordinates of the detected of the objects to the roi box coordinates?
As I attached before, deepstream-test5 is using deepstream-app. You can directly use the probe function in the sample_apps\deepstream-app\deepstream_app.c file.
No. You need to access that with the coordinates or you can set some metadata by yourself to access that.
