File "/usr/local/bin/tlt-infer", line 10, in <module>
sys.exit(main())
File "./common/magnet_infer.py", line 26, in main
File "./makenet/scripts/inference.py", line 185, in main
File "./makenet/scripts/inference.py", line 159, in inference
File "./makenet/scripts/inference.py", line 93, in load_image_batch
ValueError: could not broadcast input array from shape (3,300,224) into shape (3,224,300)
Hi ChuongPhung,
Could you please paste the full log of running tlt-infer when you get the error?
More, could you please paste the spec file when you train the tlt model(resnet_$EPOCH.tlt)?
Hi Morganh,
Thank you for that information.
Also, I wanted to find out how exactly the “input dataloader” crops the input images - how exactly does the resize work?
For example, if the input is 600x400 and 768x384 is what I specified, how would it treat the image because the ratio is off.
Would it crop the image, or would it add padding?
What’s the best practice for images sizing on training data?
Hi tech.h4x0rz,
For classification network in TLT, dataloader will resize the input images if their width/height are different from the target size where set in the spec. PIL Interpolation method is used to resize the images.
More, from tlt user guide, Note: Classification input images do not need to be manually resized. The input dataloader resizes images as needed.
File “./common/magnet_infer.py”, line 56, in main
File “./detectnet_v2/scripts/inference.py”, line 194, in main
File “./detectnet_v2/scripts/inference.py”, line 150, in inference_wrapper_batch
File “./detectnet_v2/inferencer/trt_inferencer.py”, line 443, in infer_batch
ValueError: could not broadcast input array from shape (14745600) into shape (33841152)
