使用的jeston orin agx64GB的硬件,烧写的jet36.1,使用图中的步骤进行克隆和烧写克隆镜像到新设备
结果失败,串口打印如图
ubuntu一直卡在如图
克隆的镜像大小为
Based on the provided context, it appears that you are asking about the partition configuration for the Jetson AGX Orin 64GB module. However, the provided text does not directly answer your question.
But, I can provide some information about the Jetson AGX Orin partition configuration. According to the “How Jetson Partition Configurations Are Described” section, the Jetson AGX Orin series has identical partition configurations, which includes the Jetson AGX Orin 64GB (P3701-0005) module.
Additionally, the “Jetson AGX Orin” section provides information about the bootloader, toolchain, kernel, and other software features for the Jetson AGX Orin module. However, it does not provide specific information about the partition configuration.
If you are looking for information about the partition configuration for the Jetson AGX Orin 64GB module, I would recommend checking the “Partition Configuration” section in the “Jetson Xavier NX and Jetson AGX Xavier Boot Flow” documentation, which might provide more detailed information about the partition configuration for the Jetson AGX Orin module.
Regarding the provided text “jetson orin agx64GBjet361 image 11881233 110 KB image 1025348 105 KB ubuntu image 939279 60 KB image 940114 102 KB”, it appears to be a list of images with their corresponding sizes, but without more context, it is difficult to determine what these images are or how they relate to the Jetson AGX Orin partition configuration.
In summary, while the provided context does not directly answer your question, it does provide some information about the Jetson AGX Orin partition configuration and software features. However, more information is needed to fully understand the partition configuration for the Jetson AGX Orin 64GB module.
?????????????????????没有用
Please refer to below doc
and refer to the README_backup_restore.txt file and follow the instructions provided in Workflow 3 to perform mass flashing of the backup image.
不行,使用恢复命令时 一直报错nvrestore_partitions.sh: You are trying to flash images from a board model that does not
match the current board you’re flashing onto.
It seems like your two AGX Orin have different board config.
Please refer to another cloning rootfs methods.
