I’m attempting to launch a triton server instance with a torchscripted module. The module was trained with assistance from pytorch lightning so has many internal variables which I think is causing the below error. The torchscripted module runs without issue outside of triton. Any ideas if this is recoverable or if the torchscripted module internals will have to be modified?
I0616 17:49:31.589088 1 libtorch.cc:1004] TRITONBACKEND_ModelFinalize: delete model state
E0616 17:49:31.589125 1 model_repository_manager.cc:1213] failed to load 'model' version 1: Internal: failed to load model 'model':
Unknown type name 'NoneType':
Serialized File "code/__torch__/model.py", line 8
_dtype : int
_device : Device
trainer : NoneType
~~~~~~~~ <--- HERE
_distrib_type : NoneType
_device_type : NoneType
I0616 17:49:31.589274 1 server.cc:504]
| Repository Agent | Path |
I0616 17:49:31.589390 1 server.cc:543]
| Backend | Path | Config |
| tensorrt | <built-in> | {} |
| pytorch | /opt/tritonserver/backends/pytorch/libtriton_pytorch.so | {} |
| tensorflow | /opt/tritonserver/backends/tensorflow1/libtriton_tensorflow1.so | {} |
| onnxruntime | /opt/tritonserver/backends/onnxruntime/libtriton_onnxruntime.so | {} |
| openvino | /opt/tritonserver/backends/openvino/libtriton_openvino.so | {} |
I0616 17:49:31.589476 1 server.cc:586]
| Model | Version | Status |
| ftoi | 1 | UNAVAILABLE: Internal: failed to load model 'model': |
| | | Unknown type name 'NoneType': |
| | | Serialized File "code/__torch__/model.py", line 8 |
| | | _dtype : int |
| | | _device : Device |
| | | trainer : NoneType |
| | | ~~~~~~~~ <--- HERE |
| | | _distrib_type : NoneType |
| | | _device_type : NoneType |
