Believe me, that’s normal. For me, it’s often easier to learn by examples. I don’t think the NvDs stuff has Python specific documentation yet, however, the basic structure is documented here (and somewhere else, but i forget the link).
Please see the test 2 app in the python examples for an example of how to use nvtracker.
Please note that the lists used in the NvDs… structs are not python lists, but rather GLib lists, which are doubly linked lists. You’ll see examples of how to iterate through them in callbacks like osd_sink_pad_buffer_probe, however you may find it easier to write your own iterator wrapper like below.
instead of this:
(from <b>test 1 </b>example)
# Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
def osd_sink_pad_buffer_probe(pad,info,u_data):
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.glist_get_nvds_frame_meta()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
frame_meta = pyds.glist_get_nvds_frame_meta(l_frame.data)
except StopIteration:
break
frame_number=frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.glist_get_nvds_object_meta(l_obj.data)
break
obj_counter[obj_meta.class_id] += 1
try:
l_obj=l_obj.next
break
You can do this:
VEHICLE = 0
BICYCLE = 1
PERSON = 2
ROADSIGN = 3
# add these two generators here:
[b]def frame_meta_iterator(frame_meta_list: GLib.List
) -> Iterator[pyds.NvDsFrameMeta]:
while frame_meta_list is not None:
yield pyds.glist_get_nvds_frame_meta(frame_meta_list.data)
frame_meta_list = frame_meta_list.next
def obj_meta_iterator(obj_meta_list: GLib.List
) -> Iterator[pyds.NvDsObjectMeta]:
while obj_meta_list is not None:
yield pyds.glist_get_nvds_object_meta(obj_meta_list.data)
obj_meta_list = obj_meta_list.next[/b]
# and use them here like this to make the loops easier to read
... (at the same place bolded as above,)
[b] for frame_meta in frame_meta_iterator(batch_meta.frame_meta_list):
for obj_meta in obj_meta_iterator(frame_meta.obj_meta_list):
obj_counter[obj_meta.class_id] += 1[/b]
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
# (this is a setter, and reading from it will only return a pointer)
py_nvosd_text_params.display_text = \
f"Frame={frame_meta.frame_num} " \
f"Objects={frame_meta.num_obj_meta} " \
f"Vehicles={obj_counter[VEHICLE]} " \
f"People={obj_counter[PERSON]}"
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
return Gst.PadProbeReturn.OK
For me, anyway, it’s easier to read that way and works just the same. There might be an even easier way to iterate through the GLib lists but I don’t think their python bindings support the iterator protocol directly so you have to write your own iterators for these lists to avoid having to. The typing hints are also completely optional, ignored at runtime, and only aid to help your IDE and readers of your code to know what objects you’re dealing with.
