I’ve followed successfully the steps on the pointpillars jupyter notebook from TAO Toolkit quick start guide and there are some cells that converts the KITTI dataset (using the calib files) into the desire format to train the model. But according to the documentation for 3D Object Detection PointPillars: “PointPillars dataset does not depend on Camera information and Camera calibration.”, so maybe I understood this wrong?
My goal is to train a model using only pointcloud files with .bin extension and their label files in KITTI format. Is it possible to train a model without calib files as defined in 3D Object Detection PointPillars? Thank you in advance for any help.
While experimenting, I prepared a dataset from KITTI using only velodyne and label files (omitting the changes made using calib files in the notebook) and I was able to convert the dataset as mentioned on the documentation but an error was thrown when starting the training.
Command executed:
tao pointpillars train -e $SPECS_DIR/pointpillars.yaml -r $USER_EXPERIMENT_DIR -k $KEY
Output:
INFO: ****Start logging****
INFO: CUDA_VISIBLE_DEVICES=ALL
INFO: Database filter by min points Car: 14081 => 1
INFO: Database filter by min points Pedestrian: 2272 => 0
INFO: Database filter by min points Cyclist: 837 => 0
INFO: Loading point cloud dataset
INFO: Total samples for point cloud dataset: 3712
/opt/conda/lib/python3.8/site-packages/torch/functional.py:445: UserWarning: torch.meshgrid: in an upcoming release, it will be required to pass the indexing argument. (Triggered internally at /opt/pytorch/pytorch/aten/src/ATen/native/TensorShape.cpp:2156.)
return _VF.meshgrid(tensors, **kwargs) # type: ignore[attr-defined]
INFO: ****Start training****
epochs: 0%| | 0/80 [00:00<?, ?it/s]
Traceback (most recent call last): | 0/928 [00:00<?, ?it/s]
File “/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/pointcloud/pointpillars/scripts/train.py”, line 152, in
File “/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/pointcloud/pointpillars/scripts/train.py”, line 127, in main
File “/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/pointcloud/pointpillars/tools/train_utils/train_utils.py”, line 93, in train_model
File “/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/pointcloud/pointpillars/tools/train_utils/train_utils.py”, line 24, in train_one_epoch
File “/opt/conda/lib/python3.8/site-packages/torch/utils/data/dataloader.py”, line 521, in __next__
data = self._next_data()
File “/opt/conda/lib/python3.8/site-packages/torch/utils/data/dataloader.py”, line 1203, in _next_data
return self._process_data(data)
File “/opt/conda/lib/python3.8/site-packages/torch/utils/data/dataloader.py”, line 1229, in _process_data
data.reraise()
File “/opt/conda/lib/python3.8/site-packages/torch/_utils.py”, line 438, in reraise
raise exception
ValueError: Caught ValueError in DataLoader worker process 0.
Original Traceback (most recent call last):
File “/opt/conda/lib/python3.8/site-packages/torch/utils/data/_utils/worker.py”, line 287, in _worker_loop
data = fetcher.fetch(index)
File “/opt/conda/lib/python3.8/site-packages/torch/utils/data/_utils/fetch.py”, line 49, in fetch
data = [self.dataset[idx] for idx in possibly_batched_index]
File “/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/pointcloud/pointpillars/pcdet/datasets/general/pc_dataset.py”, line 317, in __getitem__
File “/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/pointcloud/pointpillars/pcdet/datasets/dataset.py”, line 134, in prepare_data
File “/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/pointcloud/pointpillars/pcdet/datasets/augmentor/data_augmentor.py”, line 104, in forward
File “/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/pointcloud/pointpillars/pcdet/datasets/augmentor/database_sampler.py”, line 190, in __call__
File “<__array_function__ internals>”, line 5, in stack
File “/opt/conda/lib/python3.8/site-packages/numpy/core/shape_base.py”, line 422, in stack
raise ValueError(‘need at least one array to stack’)
ValueError: need at least one array to stack
2022-08-05 07:42:15,100 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
