Hi, I’m experimenting ranom kills of the training process, example:
Epoch 51/80
293/293 [==============================] - 190s 648ms/step - loss: 0.5162
Epoch 52/80
293/293 [==============================] - 188s 640ms/step - loss: 0.4087
Epoch 53/80
293/293 [==============================] - 219s 746ms/step - loss: 0.4388
Epoch 54/80
293/293 [==============================] - 230s 784ms/step - loss: 0.4515
Epoch 55/80
149/293 [==============>...............] - ETA: 1:49 - loss: 0.3965Killed
2022-06-03 14:01:32,967 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
This can happen on early epochs (<10) or in middle epochs like the above example.
What I have tried:
Reduce batch size from 8 to 4, 2, and 1. Seems to have no effects because the problem is still there
Check processes with nvidia-smi: no other processes are active when the error occurred.
What can be:
- Images too big? I’m testing on a small dataset of 293 sample images with resolution of 4352x3264
What can be causing this error? Thank you.
• Hardware (T4/V100/Xavier/Nano/etc) NVIDIA GeForce RTX 2080 Ti
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) Yolo_v3
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
Configuration of the TAO Toolkit Instance
dockers:
nvidia/tao/tao-toolkit-tf:
v3.21.11-tf1.15.5-py3:
docker_registry: nvcr.io
tasks:
1. augment
2. bpnet
3. classification
4. dssd
5. emotionnet
6. efficientdet
7. fpenet
8. gazenet
9. gesturenet
10. heartratenet
11. lprnet
12. mask_rcnn
13. multitask_classification
14. retinanet
15. ssd
16. unet
17. yolo_v3
18. yolo_v4
19. yolo_v4_tiny
20. converter
v3.21.11-tf1.15.4-py3:
tasks:
1. detectnet_v2
2. faster_rcnn
nvidia/tao/tao-toolkit-pyt:
v3.21.11-py3:
tasks:
1. speech_to_text
2. speech_to_text_citrinet
3. text_classification
4. question_answering
5. token_classification
6. intent_slot_classification
7. punctuation_and_capitalization
8. action_recognition
v3.22.02-py3:
tasks:
1. spectro_gen
2. vocoder
nvidia/tao/tao-toolkit-lm:
v3.21.08-py3:
tasks:
1. n_gram
format_version: 2.0
toolkit_version: 3.22.02
published_date: 02/28/2022
• Training spec file(If have, please share here)
random_seed: 42
yolov3_config {
big_anchor_shape: "[(514.17, 78.47), (220.24, 217.41), (642.07, 120.47)]"
mid_anchor_shape: "[(294.79, 47.24), (169.48, 112.35), (156.00, 184.47)]"
small_anchor_shape: "[(30.97, 30.12), (112.12, 67.47), (108.68, 127.88)]"
matching_neutral_box_iou: 0.7
arch: "resnet"
nlayers: 18
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 1.0
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
use_multiprocessing: true
batch_size_per_gpu: 1
num_epochs: 80
enable_qat: false
checkpoint_interval: 10
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 1e-6
max_learning_rate: 1e-4
soft_start: 0.1
annealing: 0.5
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
resume_model_path: "/workspace/tao-experiments/tao_yolo_v3_01/experiment_dir_unpruned/yolov3_resnet18_epoch_040.tlt"
# pretrain_model_path: "/workspace/tao-experiments/tao_yolo_v3_01/pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5"
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
top_k: 200
force_on_cpu: True
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 608
output_height: 608
output_channel: 3
randomize_input_shape_period: 0
dataset_config {
data_sources: {
tfrecords_path: "/workspace/tao-experiments/data/tfrecords/insulators_test_dataset/train/train*"
image_directory_path: "/workspace/tao-experiments/data/insulators_test_dataset/train/"
include_difficult_in_training: true
image_extension: "jpeg"
target_class_mapping {
key: "insulator"
value: "insulator"
validation_data_sources: {
tfrecords_path: "/workspace/tao-experiments/data/tfrecords/insulators_test_dataset/test/test*"
image_directory_path: "/workspace/tao-experiments/data/insulators_test_dataset/test/"
