• Hardware Platform (Jetson / GPU): Jetson Nvidia Xavier NX
• DeepStream Version: 6.0
• TensorRT Version: 8.2.1.8
• NVIDIA GPU Driver Version (valid for GPU only):
Hi
I tried to serialize a yolov8-Segmentation Network but it fails.
I converted the YoloV8 Model using the instructions given from GitHub - marcoslucianops/DeepStream-Yolo-Seg: NVIDIA DeepStream SDK 6.3 / 6.2 / 6.1.1 / 6.1 / 6.0.1 / 6.0 implementation for YOLO-Segmentation models .
When trying to generate the TRT it fails with the following error.
I also like to mention that I used many yoloV8 models for object detection and I never had an issue while serializing.
The issue only occurs when using segmentation model.
nvidia@ubuntu:/etc/stereo_camera/dnn/DeepStream-Yolo-Seg$ deepstream-app -c deepstream_app_config.txt
Using winsys: x11
ERROR: Deserialize engine failed because file path: /etc/villiger/gripper/seg_dnn/yolov8s-seg.onnx_b1_gpu0_fp32.engine open error
0:00:03.498454304 7679 0x7f300022c0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/etc/villiger/gripper/seg_dnn/yolov8s-seg.onnx_b1_gpu0_fp32.engine failed
0:00:03.521018368 7679 0x7f300022c0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/etc/villiger/gripper/seg_dnn/yolov8s-seg.onnx_b1_gpu0_fp32.engine failed, try rebuild
0:00:03.521485568 7679 0x7f300022c0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:366: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: Tensor DataType is determined at build time for tensors not marked as input or output.
WARNING: [TRT]: onnx2trt_utils.cpp:392: One or more weights outside the range of INT32 was clamped
ERROR: [TRT]: ModelImporter.cpp:773: While parsing node number 449 [RoiAlign -> "/1/RoiAlign_output_0"]:
ERROR: [TRT]: ModelImporter.cpp:774: --- Begin node ---
ERROR: [TRT]: ModelImporter.cpp:775: input: "/0/model.22/proto/cv3/act/Mul_output_0"
input: "/1/Reshape_1_output_0"
input: "/1/Gather_1_output_0"
output: "/1/RoiAlign_output_0"
op_type: "RoiAlign"
attribute {
s: "half_pixel"
type: STRING
attribute {
s: "avg"
type: STRING
attribute {
i: 320
type: INT
attribute {
i: 320
type: INT
attribute {
i: 0
type: INT
attribute {
f: 0.25
type: FLOAT
ERROR: [TRT]: ModelImporter.cpp:776: --- End node ---
ERROR: [TRT]: ModelImporter.cpp:779: ERROR: builtin_op_importers.cpp:4870 In function importFallbackPluginImporter:
[8] Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
ERROR: Failed to parse onnx file
ERROR: failed to build network since parsing model errors.
ERROR: failed to build network.
0:00:04.630773120 7679 0x7f300022c0 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:04.656896928 7679 0x7f300022c0 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:04.657157920 7679 0x7f300022c0 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:04.657713088 7679 0x7f300022c0 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:04.657768064 7679 0x7f300022c0 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Config file path: /etc/stereo_camera/dnn/DeepStream-Yolo-Seg/config_infer_primary_yoloV8_seg.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: <main:707>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
