I was copying TRT_object_detection.
How do I change main.py to use a model I retrained, not a coco model here?
import os
import sys
import cv2
import time
import ctypes
import numpy as np
import pycuda.autoinit
import pycuda.driver as cuda
import coco
import uff
import tensorrt as trt
import graphsurgeon as gs
#from config import model_ssd_inception_v2_coco_2017_11_17 as model
#from config import model_ssd_mobilenet_v1_coco_2018_01_28 as model
from config import model_ssd_mobilenet_v2_coco_2018_03_29 as model
ctypes.CDLL(“lib/libflattenconcat.so”)
COCO_LABELS = coco.COCO_CLASSES_LIST
initialize
TRT_LOGGER = trt.Logger(trt.Logger.INFO)
trt.init_libnvinfer_plugins(TRT_LOGGER, ‘’)
runtime = trt.Runtime(TRT_LOGGER)
compile model into TensorRT
if not os.path.isfile(model.TRTbin):
dynamic_graph = model.add_plugin(gs.DynamicGraph(model.path))
uff_model = uff.from_tensorflow(dynamic_graph.as_graph_def(), model.output_name, output_filename=‘tmp.uff’)
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, trt.UffParser() as parser:
builder.max_workspace_size = 1 << 28
builder.max_batch_size = 1
builder.fp16_mode = True
parser.register_input('Input', model.dims)
parser.register_output('MarkOutput_0')
parser.parse('tmp.uff', network)
engine = builder.build_cuda_engine(network)
buf = engine.serialize()
with open(model.TRTbin, 'wb') as f:
f.write(buf)
create engine
with open(model.TRTbin, ‘rb’) as f:
buf = f.read()
engine = runtime.deserialize_cuda_engine(buf)
create buffer
host_inputs =
cuda_inputs =
host_outputs =
cuda_outputs =
bindings =
stream = cuda.Stream()
for binding in engine:
size = trt.volume(engine.get_binding_shape(binding)) * engine.max_batch_size
host_mem = cuda.pagelocked_empty(size, np.float32)
cuda_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(cuda_mem))
if engine.binding_is_input(binding):
host_inputs.append(host_mem)
cuda_inputs.append(cuda_mem)
else:
host_outputs.append(host_mem)
cuda_outputs.append(cuda_mem)
context = engine.create_execution_context()
inference
#TODO enable video pipeline
#TODO using pyCUDA for preprocess
ori = cv2.imread(sys.argv[1])
image = cv2.cvtColor(ori, cv2.COLOR_BGR2RGB)
image = cv2.resize(image, (model.dims[2],model.dims[1]))
image = (2.0/255.0) * image - 1.0
image = image.transpose((2, 0, 1))
np.copyto(host_inputs[0], image.ravel())
start_time = time.time()
cuda.memcpy_htod_async(cuda_inputs[0], host_inputs[0], stream)
context.execute_async(bindings=bindings, stream_handle=stream.handle)
cuda.memcpy_dtoh_async(host_outputs[1], cuda_outputs[1], stream)
cuda.memcpy_dtoh_async(host_outputs[0], cuda_outputs[0], stream)
stream.synchronize()
print("execute times "+str(time.time()-start_time))
output = host_outputs[0]
height, width, channels = ori.shape
for i in range(int(len(output)/model.layout)):
prefix = i*model.layout
index = int(output[prefix+0])
label = int(output[prefix+1])
conf = output[prefix+2]
xmin = int(output[prefix+3]*width)
ymin = int(output[prefix+4]*height)
xmax = int(output[prefix+5]*width)
ymax = int(output[prefix+6]*height)
if conf > 0.7:
print("Detected {} with confidence {}".format(COCO_LABELS[label], "{0:.0%}".format(conf)))
cv2.rectangle(ori, (xmin,ymin), (xmax, ymax), (0,0,255),3)
cv2.putText(ori, COCO_LABELS[label],(xmin+10,ymin+10), cv2.FONT_HERSHEY_SIMPLEX, 1, (255,255,255), 2, cv2.LINE_AA)
cv2.imwrite(“result.jpg”, ori)
cv2.imshow(“result”, ori)
cv2.waitKey(0)
