[03/02/2023-09:19:46] [E] Error[2]: [eglUtils.cpp::operator()::72] Error Code 2: Internal Error (Assertion (eglCreateStreamKHR) != nullptr failed. )
[03/02/2023-09:19:46] [E] Error[2]: [builder.cpp::buildSerializedNetwork::636] Error Code 2: Internal Error (Assertion engine != nullptr failed. )
[03/02/2023-09:19:46] [E] Engine could not be created from network
[03/02/2023-09:19:46] [E] Building engine failed
[03/02/2023-09:19:46] [E] Failed to create engine from model or file.
[03/02/2023-09:19:46] [E] Engine set up failed
[03/04/2023-21:58:47] [W] [TRT] Unable to determine GPU memory usage
[03/04/2023-21:58:47] [I] [TRT] [MemUsageChange] Init CUDA: CPU +5, GPU +0, now: CPU 17, GPU 0 (MiB)
[03/04/2023-21:58:47] [W] [TRT] CUDA initialization failure with error: 222. Please check your CUDA installation: http://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html
[03/04/2023-21:58:47] [E] Builder creation failed
[03/04/2023-21:58:47] [E] Failed to create engine from model or file.
[03/04/2023-21:58:47] [E] Engine set up failed
I resolved the build failure by adding the tegra-gl folder into the LD_LIBRARY_PATH; however, the resulting model’s inference is dismal.
6.58 FPS with the DLACore enabled, 42.71 FPS without. Also with the DLACore enabled TensorRT seems to be creating an arbitrary GL context preventing business logic from creating one resulting in application crash.
Correct me if I am wrong, but I was under the impression that running mixed precision across the dep learning cores with gpu fallback was expected to increase the performance of inference. (puzzled).
