Trtexec not found on AGX Orin Dev Kit
• Hardware Platform (Jetson / GPU): Jetson AGX Orin Dev Kit
• DeepStream Version: 6.3
• JetPack Version (valid for Jetson only): 5.1.2
• TensorRT Version: 8.5.2
• NVIDIA GPU Driver Version (valid for GPU only): R35.6.0
• Issue Type( questions, new requirements, bugs):
Problem: Trying to convert an ONNX file to TensorRT Engine using trtexec. There is no /usr/src/tensorrt directory and it is not found running sudo find / -name trtexec
on Jetpack 6.2 it is in libnvinfer-bin and I’d imagine it was back in 5.1.2 .
sudo apt install libnvinfer-bin
will install it here.
/usr/src/tensorrt/bin/trtexec
Please check if you have installed TensorRT on your device:
 $ sudo apt install nvidia-tensorrt-dev
