Hi, I’m trying to get the trt engine from .onnx file. Im using the trtexec bin at the
/usr/src/tensorrt/bin/trtexec
but it gives the error
[09/25/2023-11:39:22] [E] [TRT] INVALID_ARGUMENT: getPluginCreator could not find plugin NonMaxSuppression version 1
ERROR: builtin_op_importers.cpp:3661 In function importFallbackPluginImporter:
[8] Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
One solution I’ve found is to remove --end2end flag while compiling the .onnx file but I want the NMS plugin so it is better to compile the model with --end2end argument. Is there any way that I can import the plugin to my TensorRT? Thanks a lot.
System specs:
- Ubuntu 18.04
- Jetpack 4.4.1
- TensorRT 7.1.3
- Jetson TX2
