Trtexec: version `GLIBCXX_3.4.26' not found
I’m trying to run the following nvcr images on NX with JetPack 5.0.2:
nvcr.io/nvidia/l4t-tensorrt:r8.2.1-runtime
nvcr.io/nvidia/l4t-tensorrt:r8.0.1-runtime
Calling trtexec from within this images crashes::
# /usr/src/tensorrt/bin/trtexec
/usr/src/tensorrt/bin/trtexec: /lib/aarch64-linux-gnu/libm.so.6: version `GLIBC_2.29' not found (required by /usr/lib/aarch64-linux-gnu/tegra/libnvdla_compiler.so)
/usr/src/tensorrt/bin/trtexec: /usr/lib/aarch64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /usr/lib/aarch64-linux-gnu/tegra/libnvdla_compiler.so)
/usr/src/tensorrt/bin/trtexec: /lib/aarch64-linux-gnu/libm.so.6: version `GLIBC_2.29' not found (required by /usr/lib/aarch64-linux-gnu/tegra/libnvtvmr.so)
These images are not backwards compatible?
No, please make sure the native OS and docker tag are aligned.
For example, the container should use r35.1 for JetPack 5.0.2.
