TensorRT: Could not open leanRuntime: GLIBC_2.34 not found
Software Version
[√] DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[√] Linux
QNX
other
Hardware Platform
[√] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[√] 2.1.0
other
Host Machine Version
[√] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
We use TensorRT version compatibility feature to be able to use engines serialized across ORIN boards with different TRT patch versions. We’ve got a number of ORIN kits with TRT 8.6.2 and 8.6.13, and we use the following steps to validate version compatibility between different boards, using /usr/src/tensorrt/data/resnet50/ResNet50.onnx natively shipped with TRT.
On one board we run:
/usr/src/tensorrt/bin/trtexec --onnx=ResNet50.onnx --saveEngine=ResNet50.bin --versionCompatible --nativeInstanceNorm
Then on another board we try loading the serialized engine with:
/usr/src/tensorrt/bin/trtexec --loadEngine=ResNet50.bin --versionCompatible
This works well when serializing on TRT 8.6.13 then loading with TRT 8.6.2, however when we try the other way around (serializing on TRT 8.6.2 then attempting to load with TRT 8.6.13), we get an error message Could not open leanRuntime: GLIBC_2.34 not found. Please advise if there’s any work-around that would allow using an engine serialized with TRT 8.6.2 on TRT 8.6.13.
Error String
[E] Error[6]: [libLoader.cpp::Impl::307] Error Code 6: Internal Error (Could not open leanRuntime from file /tmp/leanRuntime8d99b0377b1e6e7b: /usr/lib/aarch64-linux-gnu/libc.so.6: version 'GLIBC_2.34' not found (required by /tmp/leanRuntime8d99b0377b1e6e7b))
Dear @oleg.polonsky ,
Did you generate the TRT models on Drive Devkit. May I know the used DRIVE OS version to generate TRT engine?
The model was generated on Jetson R36 and failed to load on DRIVE OS 6.0.10; while it works the other way generating on DRIVE OS 6.0.10 (Ubuntu 20.04) then loading on Jetson R36 (Ubuntu 22.04). Is there any way to make it work on DRIVE OS 6.0.10?
Looks like leap runtime is not fully verified on TRT 8.6. we recommend you to generate model using the same TRT version.
