Is there pre-built TensorRT Python package for DRIVE AGX Orin?
Software Version
[1] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1] Linux
QNX
other
Hardware Platform
[1] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[1] 1.9.10816
other
Host Machine Version
[1] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Can I install pre-built TensorRT Python package via pip?
Dear @WanchaoYao,
Is the ask you want to install TensorRT python libs on target using pip or on host for DRIVE OS 6.0.5 release?
Dear @WanchaoYao,
There is no prebuilt python package of TensorRT. May I know if it is critical for your development? Can you use TRT C++ APIs for your development on DRIVE AGX Orin?
@SivaRamaKrishnaNV Yes. Because our model deployment code are written by TRT Python API.
Fortunately, I have already installed TRT OSS python bindings after a lot effort.
Dear @WanchaoYao,
Glad to hear you could compile TRT OSS python binding and install. Please share the steps and issues you have faced to help others in the community.
@SivaRamaKrishnaNV The key steps are:
  1. Install TRT OSS
    cmake -DTRT_OUT_DIR=pwd/out -DTRT_PLATFORM_ID=aarch64 -DCMAKE_CUDA_COMPILER=/usr/local/cuda/bin/nvcc -DCUDA_VERSION=11.4 -DTRT_LIB_DIR=/lib/aarch64-linux-gnu/ -DCUDNN_LIB=/lib/aarch64-linux-gnu/libcudnn.so.8 -DTENSORRT_LIBRARY_INFER=/lib/aarch64-linux-gnu/libnvinfer.so.8 -Dnvinfer_LIB_PATH=/lib/aarch64-linux-gnu/libnvinfer.so.8 -Dnvparsers_LIB_PATH=/lib/aarch64-linux-gnu/libnvparsers.so.8 -DTENSORRT_LIBRARY_INFER_PLUGIN=/lib/aarch64-linux-gnu/libnvinfer_plugin.so.8 -DBUILD_ONNX_PYTHON=ON ..
  2. Install python bindings according to TensorRT/python at main · NVIDIA/TensorRT · GitHub
export EXT_PATH=~/external
mkdir -p $$EXT_PATH && cd $$EXT_PATH
git clone https://github.com/pybind/pybind11.git
# Add Main Headers
cd ~/external
wget https://www.python.org/ftp/python/3.8.10/Python-3.8.10.tar.xz
tar -xf Python-3.8.10.tar.xz
mkdir -p python-3.8
cp -r Python-3.8.10/Include/ python3.8/include
# Add PyConfig.h
sudo mkdir /usr/include/aarch64-linux-gnu/python3.8m
sudo apt install libpython3.8-dev
sudo cp /usr/include/aarch64-linux-gnu/python3.8/pyconfig.h /usr/include/aarch64-linux-gnu/python3.8m
sudo ln -s /usr/lib/aarch64-linux-gnu/libnvinfer.so.8 /usr/lib/aarch64-linux-gnu/libnvinfer.so
sudo ln -s /usr/lib/aarch64-linux-gnu/libnvonnxparser.so.8 /usr/lib/aarch64-linux-gnu/libnvonnxparser.so
sudo ln -s /usr/lib/aarch64-linux-gnu/libnvparsers.so.8 /usr/lib/aarch64-linux-gnu/libnvparsers.so
sudo ln -s /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.8 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so
cd $TRT_OSSPATH/python
export PYTHON=3.8
EXT_PATH=/home/nvidia/external PYTHON_MAJOR_VERSION=3 PYTHON_MINOR_VERSION=8 TARGET_ARCHITECTURE=aarch64 bash ./build.sh
pip install build/dist/tensorrt-*.whl
The built whl is uploaded. Hope it can help somebody.
tensorrt-8.2.0.6-cp38-none-linux_aarch64.whl (776.0 KB)
Dear @WanchaoYao,
Thank you for sharing the information.
