Tensor RT installation on NVIDIA Drive PX2 OS
Dear Team,
I am trying to install TensorRT on Drive PX2 OS Tegra A, but failing to get the TensorRT build.
I tried to install x86_64 and amd64 architecture TensorRT which failed as board as arch64 architecture.
I need arch64-based TensorRT version 3.0.2 or 3.0.4 or the latest version of the Tensor RT arch64-based installation file and installation guide for directly installing tensorRT On target device.
I have a few more queries regarding the environment setup on the target directly, issues faced are below:
  1. failed to install anaconda
  2. failed to install python-based dependencies for model porting
  3. failed to setup tensorRT
Let me know if it is possible to set up the model requirements for python-based dependencies directly on board OS.
Kindly do the needful.
Thanks and Regards,
Vyom Mishra
Hi @vyom.mishra
You can not install TensorRT as a standalone package. Also, TensorRT does not have python bindings on DRIVE platform. You need to use C++ APIs.
You need to flash the target using sdkmanager to get last release(DRIVE OS 5.0.10.3 with DriveWorks SDK ).
May I know what is the current DRIVE version installed on target?
Sorry for late reply!
I am able to install latest available package with Drive PX2 through SDK manager, tensorrt is installed with the package itself.
Thanks for your kind help!
Regards,
Vyom Mishra
