I have Drive Software 10.0 installed with the SDK Manager. I expect that TensorRT Version 5.1.4 should automatically be installed on the target as part of this package.
How do I verify that TensorRT has correctly been installed on the Drive AGX?
I can see libnvinfer.so.5.1.4 in /usr/local/driveworks/lib/.
However, i do not get any succesful response with:
dpkg -l | grep nvinfer
Is this normal or do I need further steps to install TensorRT?
When trying to import NvInfer.h, I receive an error that the file does not exist. Is this just a linking error or is the package not correctly installed?
Also, is the TensorRT Python API still not supported for the Drive AGX?
Dear @philipp.heidenreichdo0x6,
In DRIVE SW 10.0, we have removed all header filers and TensorRT samples on target to save filesystem space. The TensorRT libs are expected to present at driveworks lib location. So, you are expected to cross compile TensorRT sample on host and link the libs on target for execution.
TensorRT Python API is not supported on DRIVE AGX platform.
OK, we do not need the samples, so this is not the issue.
To clarify:
Is it expected that “dpkg -l | grep nvinfer” lists my TensorRT Version when installed correctly on the Nvidia Drive AGX? Or is it sufficient when libnvinfer.so.5.1.4 is inside the /usr/local/driveworks/lib/ directory?
My main issue is that I can’t find the header files needed to compile a minimum working example of TensorRT (ideally with ONNX Parser). I do find the shared libraries of libnvinfer.so.5, libnvparsers.so and libnvonnxparser.so.0 inside /usr/local/driveworks/lib/ and inside /usr/local/driveworks/targets/aarch64_Linux/lib/. But I do not find any header files like NvInfer.h. Where should they be located?
When i try: #include NvInfer.h
I get: “No such file or directory” even though I did:
target_link_libraries(my_project nvinfer nvparsers nvonnxparser)
in my CMakeLists.txt.
Before we have any update, please try to extract deb packages from ~/Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.6.1-16911241-aarch64-tensorrt-5.1.4.2-1+cuda10.2.run and install on your target machine.
BTW, NvInfer.h should be in libnvinfer-dev_5.1.4-1+cuda10.2_arm64.deb in the run file.
We haven’t got any progress due to the holiday season.
Have you manually installed the deb packages in ~/Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.6.1-16911241-aarch64-tensorrt-5.1.4.2-1+cuda10.2.run on you target system? All packages you need should be there.
