I’m trying to install the TRTorch on my brand new Xavier AGX, flashed with JetPack 4.4.
The problem is that TRTorch supports pytorch 1.5.1 and we don’t have the pytorch 1.5.1 available for Jetson. I checked the l4t-pytorch docker containers and we just have 1.5.0 and 1.6.0. Both fail, as cuda version is different (1.5.0) and header files changed (for 1.6.0).
Do you know how to install pytorch 1.5.1 in xavier agx ?
Is some change in progress to make it work on the 1.6.0?
The TRTorch works on pytorch 1.5.1 only. And I can’t find this version available for Jetson. The docker containers are only 1.5.0 and 1.6.0. Could you assist me how to get the pytorch 1.5.1 working on jetson JetPack 4.4?
Answering your question: the error when building TRTorch is that it can’t find the quantitizer.h header file, which was removed from pytorch 1.5.1 to 1.6.0 version.
JetPack4.4 product release is using r32.4.3 OS image.
So the r32.4.2-pth1.5-py3 cannot work on it.
Please give JetPack 4.4 DP a try, which uses r32.4.2.
The reason for this is that our TRTorch doesn’t support 1.6.0 yet.
We will pass this issue to our internal team.
