I am getting a lot of unwanted output in my terminal when I use NVIDIA’s GStreamer elements such as nvvidconv and nvv4l2h264enc. Is it possible to turn off or reduce this output so that other debugging output is more visible?
This is an example of the output that I am seeing that I would like to suppress if possible:
nvbuf_utils: Could not get EGL display connection
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 279
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 279
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
NVMEDIA_ENC: bBlitMode is set to TRUE
