Disable logs from NvMMLite calls
Hi, we are running Yocto Linux (based on JetPack 6.1, L4T 36.4.0) on a custom board with Jetson AGX Orin 64GB SoM. When we start a decode session with gstreamer using the nvv4l2decoder element, we always get these logs from NvMMLite. Example:
gst-launch-1.0 filesrc location=/opt/tegra-mmapi/data/Video/sample_outdoor_car_1080p_10fps.h264 ! h264parse ! nvv4l2decoder ! fakesink
# some other logs ...
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
I assume these logs are from calls to libnvmmlite.so functions, which we cannot directly modify. We are trying to disable these logs since they are spamming our log pool. Is there any way to disable these logs (e.g. setting an env variable)?
These cannot be disabled. These are only printed in beginning of decoding. Should not be spamming the logs.
