Hi;
I have just flashed my Tegra TX1 board with Jetpack 3.1.
I have problems with the onboard Ethernet. It works in Linux, but it doesn’t work in U-Boot. For me it is important that Ethernet is also available in U-Boot, since I need a way to boot via DHCP/NFS for maintanence and development work. For normal operation the system should boot from the embedded EMMC.
-----Console Log-------
Tegra210 (P2371-2180) # version
U-Boot 2016.07-g0ce7ca2 (Jul 20 2017 - 00:37:03 -0700)
aarch64-unknown-linux-gnu-gcc (GCC) 4.8.5
GNU ld (GNU Binutils) 2.24
Tegra210 (P2371-2180) # dhcp
No ethernet found.
Tegra210 (P2371-2180) # ping 192.168.100.10
No ethernet found.
ping failed; host 192.168.100.10 is not alive
Tegra210 (P2371-2180) # usb start
starting USB…
USB0: USB EHCI 1.10
scanning bus 0 for devices… 1 USB Device(s) found
Tegra210 (P2371-2180) # usb info
1: Hub, USB Revision 2.0
- u-boot EHCI Host Controller
- Class: Hub
- PacketSize: 64 Configurations: 1
- Vendor: 0x0000 Product 0x0000 Version 1.0
Configuration: 1- Interfaces: 1 Self Powered 0mA
Interface: 0- Alternate Setting 0, Endpoints: 1
- Class Hub
- Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms
The dhcp and ping commands say “No ethernet found”. Since the Ethernet chip is connected via USB, it should be visible after “usb start” and “usb info”, but usb3 seems to be missing here.
The binaries on the board are the unmodified ones from Jetpack 3.1.
What’s wrong here?
Regards
Frank-Christian Kruegel
Embedded Hard/Software Developer
OptoPrecision GmbH
