As part of a project I want to recreate the TX1’s PCB.
To do this, I downloaded all the OrCAD files made available by NVidia and then bought an OrCAD license.
I can easily open the files separately. However, I can not connect the schematic file to the PCB file.
When importing the Netlist, there are the following problems.
[b]
#1 WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-194): Symbol ‘402’ used by RefDes C10 for device ‘C_402_0.1UF_10%’ not found in PSMPATH or must be "dbdoctor"ed.
#2 WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-194): Symbol ‘402’ used by RefDes C100 for device ‘C_402_1UF_10%’ not found in PSMPATH or must be "dbdoctor"ed.
#3 WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-194): Symbol ‘402’ used by RefDes C101 for device ‘C#1_402_0.1UF_10%’ not found in PSMPATH or must be "dbdoctor"ed.
#4 WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-194): Symbol ‘603’ used by RefDes C106 for device ‘C_603_1UF_10%’ not found in PSMPATH or must be "dbdoctor"ed.[/b]
It seems to be missing the link to the library of resistors and capacitors. But I do not know where they are in the set of design files.
Can you help me find a solution?
Link:
Jetson TX1-TX2 Developer Kit Carrier Board Design Files
https://developer.nvidia.com/embedded/downloads#?search=tx1&tx=$hardware,design,schematics
