Based on Updating the Bootloader Pinmux the following FAILED. I was testing so I redirected output to see what was going to be created, fat chance.
kernel/pinmux/t186$ python pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt --mandatory_pinmux_file mandatory_pinmux.txt \
tegra18x-jetson-tx2-default-template-pinmux.dtsi \ tegra18x-jetson-tx2-default-template-gpio-default.dtsi 1.0 \ > junk.cfg
usage: pinmux [–pinmux] [–mandatory_pinmux_file MANDATORY_PINMUX_FILE]
[–mask] [–help]
address_info_file gpio_address_file por_val_file pinmux_dts_file
gpio_dts_file version
pinmux: error: argument pinmux_dts_file: can’t open ‘tegra18x-jetson-tx2-default-template-pinmux.dtsi’: [Errno 2] No such file or directory: ‘tegra18x-jetson-tx2-default-template-pinmux.dtsi’
Help
Terry
