Hi Sir/Madam,
I follow NV document to use spreadsheet to config pinmux but the setting isn’t applied.
(Original spreadsheet has errors so I use updated spreadsheet as following link)
https://devtalk.nvidia.com/default/topic/1023417/jetson-tx2/pinmux-dts2cfg-py-gives-errors-from-default-pinmux/post/5208337/#5208337
Here are the steps I use
Use “Jetson-TX2-Generic-Customer-Pinmux-Template (3).xlsm” and “mandatory_pinmux.txt” in the following link.
https://devtalk.nvidia.com/default/topic/1023417/jetson-tx2/pinmux-dts2cfg-py-gives-errors-from-default-pinmux/post/5208337/#5208337 -
Generate three DT files from “Jetson-TX2-Generic-Customer-Pinmux-Template (3).xlsm”
tegra18x-jetson-tx2-config-template–gpio-default.dtsi
tegra18x-jetson-tx2-config-template–padvoltage-default.dtsi
tegra18x-jetson-tx2-config-template–pinmux.dtsi -
dos2unix to convert files
Copy step2 three files and “mandatory_pinmux.txt” to Linus_for_Tegra/kernel/pinmux
python pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt mandatory_pinmux.txt tegra18x-jetson-tx2-config-template-pinmux.dtsi tegra18x-jetson-tx2-config-template-gpio-default.dtsi 1.0 > tegra186-quill-p3310-1000-a00-pinmux-gpio.cfg
python pinmux-dts2cfg.py --pad pad_info.txt tegra18x-jetson-tx2-config-template-padvoltage-default.dtsi 1.0 > tegra186-mb1-bct-pad-quill-char-e3301-1080-a00.cfg
cpoy tegra186-quill-p3310-1000-a00-pinmux-gpio.cfg and tegra186-mb1-bct-pad-quill-char-e3301-1080-a00.cfg to Linux_for_Tegra/bootloader/t186ref/BCT
sudo ./flash.sh jetson-tx2 mmcblk0p1
I also check the flash log, the two .cfg files not be flashed. Please check the attachment.
- tegra186-quill-p3310-1000-a00-pinmux-gpio.cfg
- tegra186-mb1-bct-pad-quill-char-e3301-1080-a00.cfg
Is to use spreadsheet to config pinmux workable on r28.1 with TX2?
flash.log (244 KB)
