Hi, NV team,
i am trying to change the pinmux of my custom tx2 board. so i refered to “TX2 Configuring Pinmux GPIO and PAD” of the “NVIDIA Tegra Linux Driver Package Development Guide 28.2 Release”
i thought the first step of controlling pins of my custom board is to use generic Jetson-TX2-Generic-Customer-Pinmux-Template.xlsm, and if i succeed on booting the board with the CFG file of MB1, i will modify the Jetson-TX2-Generic-Customer-Pinmux-Template.xlsm for my custom board.
anyway, i succeed on getting the three dtsi files and two CFG files without any warning or error so i checked and modified the name value of PINMUX_CONFIG, PMC_CONFIG variable in the p2771-0000.conf.common like below
SCR_COLD_BOOT_CONFIG="mobile_scr.cfg";
MISC_CONFIG="tegra186-mb1-bct-misc-si-l4t.cfg";
#PINMUX_CONFIG="tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg";
PINMUX_CONFIG="tegra186-myboard-mb1-bct-pinmux-quill-p3310-1000-a00.cfg";
PMIC_CONFIG="tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg";
#PMC_CONFIG="tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg";
PMC_CONFIG="tegra186-myboard-mb1-bct-pad-quill-p3310-1000-a00.cfg";
but when i fused my tx2 based custom board with these two cfg files, it failed to boot. here is boot message
[0136.289] E> MB1 BCT does not have PMC table
[0136.293] E> PMC init failed
[0136.296] E> MB1 BCT does not have pinmux table
[0136.300] E> Pinmux init failed
[0136.304] W> MB1 PMIC CFG is version 1.2
[0136.307] W> Rail ID 7 is not found on MB1 BCT
[0136.312] W> MB1 PMIC CFG is version 1.2
[0136.317] C> I2C command failed
[0136.320] C> block index = (0) and rail_id = (1)
[0136.324] C> Addr: Reg = [0x78:0x00]: 336166918
[0136.330] C> I2C command failed
[0136.333] C> block index = (1) and rail_id = (1)
[0136.338] C> Addr: Reg = [0x78:0x31]: 336166918
[0136.343] C> I2C command failed
[0136.346] C> block index = (2) and rail_id = (1)
[0136.351] C> Addr: Reg = [0x78:0x2b]: 336166918
[0136.356] C> I2C command failed
[0136.359] C> block index = (3) and rail_id = (1)
[0136.364] C> Addr: Reg = [0x78:0x2a]: 336166918
[0136.369] E> tegrabl_i2c_open: failed error = 13098006
[0136.374] C> I2C command failed
[0136.377] C> block index = (4) and rail_id = (1)
[0136.381] C> Addr: Reg = [0xe8:0x07]: 336199953
[0136.386] W> MB1 PMIC CFG is version 1.2
[0136.394] C> I2C command failed
[0136.397] C> block index = (2) and rail_id = (3)
[0136.401] C> Addr: Reg = [0x78:0x2f]: 336166918
[0136.406] W> Failed to bringup CORE rails
[0136.410] W> MB1 PMIC CFG is version 1.2
[0136.415] C> I2C command failed
[0136.418] C> block index = (0) and rail_id = (6)
[0136.422] C> Addr: Reg = [0x78:0x22]: 336166918
[0136.427] E> Failed to bringup MEMIO rails
[0136.431] I> sdram slot : 1
[0136.433] I> Initializing SDRAM
[0136.440] I> mss encrypt status check successful
[0136.444] I> downloaded image bct_mb1 successfully
[0136.826] I> Downloading blob at 0x0000000084800000
[0137.251] I> downloaded image blob successfully
[0137.445] I> exiting nv3p server
[0137.448] I> MB1-recovery(prd-version : 14.01.171031-t186-M-00.00-6b33ecf5)
[0137.455] I> disabled_core_mask: 0xffffff0c
[0137.459] I> Enabled Cores: 0xf3
[0137.462] I> TPC disable fuse status: 0
[0137.466] I> Booting Parker Sku
[0137.469] I> Setup temp. GSC#29 (base:0x30000000, size:0x00010000)
[0137.475] I> Loading preboot
[0137.480] I> Binary(1) of size 62224 is loaded @ 0x40000000
[0137.485] I> Restrict GSC#29 access to DPMU only
[0137.490] I> Updated LSR_DVCOMP_PARAMS: 0xc06e0dc5c
[0137.494] I> Updated LSR_DVCOMP_PARAMS: 0xc0740e85c
[0137.499] I> WP0 triggered
[0137.502] I> Waypoint-0 ACK received :)
[0137.506] I> WP0.5 triggered
[0137.509] I> Initialized SCRs
[0137.512] W> MB1 PMIC CFG is version 1.2
[0137.680] !!! Exception !!! [lr:0x40022b1c, dfar:0x22110c0, dfsr:0x1008]
[0137.687] MB1-BIT() boot status dump :
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0137.715] Last seen error : 0x00000000
from the error message above, i though my two pinmux and pmic config might not be valid … but i have no idea why these errors occured because i didn’t modify Jetson-TX2-Generic-Customer-Pinmux-Template.xlsm.
by the way, i have 2 questions below
first question is that i want to know why this error occurred
second question is that my tx2 custom board could be booted with default tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg, tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg files in the default L4T, now i applied jetpack3.2, so i checked these files and i found these files was made with tegra18x-p3310-1000-a0-a2-cvm-config-pinmux.dtsi and tegra18x-p3310-1000-a0-a2-cvm-config-gpio-default.dtsi.
could i get these two dts files and its original XLSM file ?
thanks previously ~
