Please help to confirm fail at what device
We don’t understand what happen ,please help to fail at what device, the debug message is following:
[0000.383] I> Boot-device: eMMC
[0000.386] I> Boot_device: SDMMC_BOOT instance: 3
[0000.392] I> sdmmc-3 params source = boot args
[0000.395] I> sdmmc bdev is already initialized
[0000.399] I> sdmmc-3 params source = boot args
[0000.408] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.414] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.415] W> No valid slot number is found in scratch register
[0000.420] W> Return default slot: _a
[0000.423] I> Active Boot chain : 0
[0000.427] I> parsing oem signed section of bpmp-fw header done
[0000.433] I> bpmp-fw binary init read from storage
[0000.438] I> oem authentication of bpmp-fw header done
[0000.444] I> bpmp-fw binary done read from storage
[0000.447] I> bpmp-fw: Authentication init Done
[0000.451] I> parsing oem signed section of cpubl header done
[0000.457] I> cpubl binary init read from storage
[0000.461] I> bpmp-fw: Authentication Finalize Done
[0000.466] I> oem authentication of cpubl header done
[0000.470] I> cpubl binary done read from storage
[0000.475] I> cpubl: Authentication init Done
[0000.480] I> parsing oem signed section of rce header done
[0000.484] I> rce binary init read from storage
[0000.489] I> Relocating BR-BCT
[0000.492] I> cpubl: Authentication Finalize Done
[0000.496] I> oem authentication of rce header done
[0000.501] I> rce binary done read from storage
[0000.505] I> rce: Authentication init Done
[0000.510] I> parsing oem signed section of ape header done
[0000.514] I> ape binary init read from storage
[0000.519] I> rce: Authentication Finalize Done
[0000.523] I> oem authentication of ape header done
[0000.527] I> ape binary done read from storage
[0000.532] I> ape: Authentication init Done
[0000.536] I> parsing oem signed section of tos header done
[0000.541] I> tos binary init read from storage
[0000.545] I> ape: Authentication Finalize Done
[0000.550] I> oem authentication of tos header done
[0000.554] I> tos binary done read from storage
[0000.558] I> tos: Authentication init Done
[0000.563] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.568] I> bpmp-fw-dtb binary init read from storage
[0000.573] I> tos: Authentication Finalize Done
[0000.579] I> oem authentication of bpmp-fw-dtb header done
[0000.586] I> bpmp-fw-dtb binary done read from storage
[0000.588] I> bpmp-fw-dtb: Authentication init Done
[0000.593] I> parsing oem signed section of cpubl-dtb header done
[0000.599] I> cpubl-dtb binary init read from storage
[0000.603] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.641] I> oem authentication of cpubl-dtb header done
[0000.641] I> cpubl-dtb binary done read from storage
[0000.642] I> cpubl-dtb: Authentication init Done
[0000.644] I> parsing oem signed section of eks header done
[0000.645] I> eks binary init read from storage
[0000.645] I> cpubl-dtb: Authentication Finalize Done
[0000.646] I> oem authentication of eks header done
[0000.649] I> eks binary done read from storage
[0000.654] I> eks: Authentication init Done
[0000.658] I> eks: Authentication Finalize Done
[0000.662] I> EKB detected (length: 0x410) @ VA:0x5270a400
▒▒NOTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 12:15:31, Oct 16 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
hello Tony_Li,
I did not see obvious errors, were those complete console logs?
please revise your comments to attach the logs by the <code> code block </code>.
thanks
From others post, the next steps should be
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
We don’t see the “emc initialized” on our board, what will cause this phenomenon ?
hello jb035.cheng,
may I also have complete console logs for reference,
did you perform a whole flashing process with SDKmanager then reproduce the issue?
thanks
We can’t flash at our board ,so we use Developer_Kit fish module , then move the module to our board ,get the message
hello Tony_Li,
that’s expect results, you may have some platform-specific data updates.
please refer to developer guide, you should also check Jetson Xavier NX and Jetson AGX Xavier Series MB1 Platform Configuration for more details of board customization.
thanks
We have no idea about this ,Please help confirm what part can be affect the boot,thanks
hello Tony_Li,
I would guess it’s caused by board configuration,
please download pinmiux spreadsheets to complete your board customization. after that, you may flash the correct *.cfg file to update the image.
thanks
I know ,but I try most of the control pin ,it is still not work normal ,so I need NV help to clear what is the “emc initialized” work function ?
had you complete your board customization to use correct *.cfg file for flashing?
Can you help to provide about the config detail,thanks
At Jetson AGX Developer Kit with 16 GB memory, but the module with 32GB memory, how about this different ,how about setting at this
hello Tony_Li,
please refer to developer guide and check Jetson Xavier NX and Jetson AGX Xavier Series MB1 Platform Configuration chapter.
there’re different MB1 configuration files for different Jetson AGX Xavier modules.
you should look into memory rail configuration, i.e. pmic.memio for comparison.
thanks
May I to know how to assign MB1 use the <device>-tegra194-mb1-bct-pmic-p2888-0004-<revision>.cfg configuration files for AGX Xavier module with 32 GB of memory?
Linux_for_Tegra/bootloader/t186ref/BCT/<device>-tegra194-mb1-bct-pmic-<partnumber>-<revision>.cfg
<partnumber> is the full part number of the device:
•p2888-0004 for the Jetson AGX Xavier module with 32 GB of memory
hello SammyChenTw,
it’s MB1 Platform Configuration process to generate a *.cfg file from the customize pinmux spreadsheets.
you should also check flashing messages, please looking for mb1-bct for the file name that flash to your target.
thanks
I am hardware engineer, I don’t have any way to solve this issue, but I think the Can we remove the most of the software files and only remain the boot file to try ,what about the file is for boot only?
hello Tony_Li,
please check the Boot Flow Jetson AGX Xavier series. it’s MB1 for the very early stage to initial the board configuration.
We don’t have idea at the issue .your agent and Taiwan FAE come here yesterday, but it is still not way to solve this issue , do you have any tool can help to check boot fail at what
the attached file is our download error message , please help to confirm about this issue
log_uart.txt (7.2 KB)
