i have a ethernet problem.
i do the full time test but some time my device ethernet will disconnect and always show the message as below
[114165.847514] rc.local[882]: need at least a destination address
[114166.147256] rc.local[882]: need at least a destination address
[114167.951357] rc.local[882]: need at least a destination address
[114168.258954] rc.local[882]: need at least a destination address
[114169.326971] rc.local[882]: need at least a destination address
after reset i can see this message.
i need to reflash device to workaround this issue
FYI, if you flash a Jetson, and make edits to the “rootfs/etc/sysctl.conf” on the host prior to flash, then those changes will appear on the Jetson itself after flash. Or you can just edit the file directly.
and i have a issue on tx2 , the syslog will be a very large file.
root@tegra-ubuntu:/var/log# ls -la
total 24068080
drwxrwxr-x 5 root syslog 4096 Dec 4 01:29 .
drwxr-xr-x 15 root root 4096 Mar 20 2018 ..
-rw-r--r-- 1 root root 0 Nov 29 06:09 alternatives.log
-rw-r--r-- 1 root root 653 Nov 29 06:04 alternatives.log.1
-rw-r----- 1 root adm 3399 Dec 4 01:30 apport.log
-rw-r----- 1 root adm 20480 Dec 3 09:14 apport.log.1
-rw-r----- 1 syslog adm 4096 Dec 4 01:34 auth.log
-rw-r----- 1 syslog adm 53248 Dec 3 09:17 auth.log.1
-rw-r----- 1 syslog adm 953 Nov 29 06:08 auth.log.2.gz
-rw------- 1 root utmp 400 Dec 4 01:30 btmp
-rw------- 1 root utmp 1200 Nov 29 06:55 btmp.1
drwxr-x--- 2 root lp 4096 Dec 4 01:04 cups
-rw-r----- 1 syslog adm 12288 Dec 4 01:31 kern.log
-rw-r----- 1 syslog adm 1589248 Dec 3 09:16 kern.log.1
-rw-r----- 1 syslog adm 24840 Nov 29 06:04 kern.log.2.gz
-rw-r--r-- 1 root root 296592 Dec 4 01:31 lastlog
drwx--x--x 2 root root 4096 Dec 4 01:04 lightdm
-rw-r----- 1 syslog adm 20480 Dec 4 01:34 syslog
-rw-r----- 1 syslog adm 24643670016 Dec 3 09:23 syslog.1
-rw-r----- 1 syslog adm 39857 Nov 29 06:09 syslog.2.gz
drwxr-xr-x 2 root root 4096 Dec 3 09:23 unattended-upgrades
-rw-rw-r-- 1 root utmp 10400 Dec 4 01:31 wtmp
-rw-rw-r-- 1 root utmp 159200 Dec 3 09:16 wtmp.1
-rw-r--r-- 1 root root 17519 Dec 4 01:31 Xorg.0.log
-rw-r--r-- 1 root root 16639 Dec 4 01:29 Xorg.0.log.old
root@tegra-ubuntu:/var/log# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 28G 27G 0 100% /
devtmpfs 7.6G 0 7.6G 0% /dev
tmpfs 7.7G 252K 7.7G 1% /dev/shm
tmpfs 7.7G 14M 7.7G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup
tmpfs 785M 0 785M 0% /run/user/1001
tmpfs 785M 28K 785M 1% /run/user/1000
In this time i find the two problem.
i can’t login with GUI , i need use ctrl+alt+F5 to change to terminal mode.
more rc.local error message will show on my debug console.
how to fixed this issue and where is this rc.local file?
i can’t find this rc.local(rc.local[882]: need at least a destination address) and trace this issue.
i use default nvidia BSP
so my re.local is as below
nvidia@tegra-ubuntu:/etc$
nvidia@tegra-ubuntu:/etc$ cat rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
touch /tmp/jetpack.log
echo "starting script to send ip to host" >> /tmp/jetpack.log
/home/nvidia/report_ip_to_host.sh &
echo "started script to send ip to host" >> /tmp/jetpack.log
exit 0
I have the same problem.
As mentioned in the comment in rc.local, /home/nvidia/report_ip_to_host.sh is run to send ip to the host (developer machine on which jetpack is installed), probably for debug purposes:
#!/bin/sh
HOST_IP=""
HOST_PORT="33338"
INTERVAL=1
SRC_IP=""
DEV=""
dhclient eth0
sleep 1
dpkg -l | grep rsync || apt-get update
apt-get install -y rsync
apt-get install -y netcat-openbsd
sleep 1
while true; do
ip route get $HOST_IP >/dev/null
if [ $? -eq 0 ]; then
SRC_IP=`ip route get $HOST_IP | grep " dev " | sed 's/.* src //'`
DEV=`ip route get $HOST_IP | grep " dev " | sed 's/.*dev \([^ ][^ ]*\).*//'`
status=`echo "$SRC_IP" | /bin/nc $HOST_IP $HOST_PORT`
fi
sleep $INTERVAL
done
That ‘while’ loop runs
but $HOST_IP is empty. So ip route displays the message ‘need at least a destination address’.
But it looks like HOST_IP is never set any non-empty value. Maybe this is a bug…
If you don’t use jetpack or don’t communicate with your jetson using jetpack (profiling and so on), just comment out lines 16 to 19 of rc.local and keep only ‘exit 0’. Then reboot.
Basically, what @eric.besombes said. Other than the “exit 0” all of the active content (unless you added it) is intended to exist after a JetPack flash…on first reboot after the flash it tries to report IP to JetPack on the host. After that the content should be erased. Why this remained after a reboot is the real mystery (perhaps something truncated?). Try commenting out everything except the “exit 0”.
If a static address is set up without removing DHCP query code, then anything which issues a DHCP request will probably set up networking upon DHCP response regardless of previous method of address setup. One would disable DHCP. The GUI app “nm-connection-editor” could be used to set IPv4 to manual instead of automatic. I don’t know about clearing of the DHCP table.
Incidentally, the “nm” name convention implies it is part of NetworkManager. NetworkManager is what you would associate with automatic configuration services, e.g., for changing to WiFi when WiFi becomes available and wired goes away. There are also other static setup methods, and the two tend to fight each other at times if not configured correctly…one does not necessarily have any knowledge of what the other does.
